Use this category:
Solved installation error
# @package Joomla
# @copyright Copyright (C) 2005 - 2019 Open Source Matters. All rights reserved.
# @license GNU General Public License version 2 or later; see LICENSE.txt
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE!
# The line 'Options +FollowSymLinks' may cause problems with some server configurations.
# It is required for the use of mod_rewrite, but it may have already been set by your
# server administrator in a way that disallows changing it in this .htaccess file.
# If using it causes your site to produce an error, comment it out (add # to the
# beginning of the line), reload your site in your browser and test your sef urls. If
# they work, then it has been set by your server administrator and you do not need to
# set it here.
## No directory listings
<IfModule autoindex>
IndexIgnore *
</IfModule>
## Suppress mime type detection in browsers for unknown types
<IfModule mod_headers.c>
Header always set X-Content-Type-Options "nosniff"
</IfModule>
## Can be commented out if causes errors, see notes above.
Options +FollowSymlinks
Options -Indexes
## Mod_rewrite in use.
RewriteEngine On
RewriteBase /
RewriteRule ^([a-z]+)\.html$ /index.php?$1 [R,L]
## Begin - Rewrite rules to block out some common exploits.
# If you experience problems on your site then comment out the operations listed
# below by adding a # to the beginning of the line.
# This attempts to block the most common type of exploit `attempts` on Joomla!
# Block any script trying to base64_encode data within the URL.
RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR]
# Block any script that includes a <script> tag in URL.
RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
# Block any script trying to set a PHP GLOBALS variable via URL.
RewriteCond %{QUERY_STRING} GLOBALS(
\[|\%[0-9A-Z]{0,2}) [OR]# Block any script trying to modify a _REQUEST variable via URL.
RewriteCond %{QUERY_STRING} _REQUEST(
\[|\%[0-9A-Z]{0,2})# Return 403 Forbidden header and show the content of the root home page
RewriteRule .* index.php [F]
## End - Rewrite rules to block out some common exploits.
## Begin - Custom redirects
# If you need to redirect some pages, or set a canonical non-www to
# www redirect (or vice versa), place that code here. Ensure those
# redirects use the correct RewriteRule syntax and the [R=301,L] flags.
## End - Custom redirects
# Uncomment the following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root).
# RewriteBase /
## Begin - Joomla! core SEF Section.
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# If the requested path and file is not /index.php and the request
# has not already been internally rewritten to the index.php script
RewriteCond %{REQUEST_URI} !^/index\.php
# and the requested path and file doesn't directly match a physical file
RewriteCond %{REQUEST_FILENAME} !-f
# and the requested path and file doesn't directly match a physical folder
RewriteCond %{REQUEST_FILENAME} !-d
# internally rewrite the request to the index.php script
RewriteRule .* index.php [L]
## End - Joomla! core SEF Section.
- Thank you received: 2544
Before I had written yesterday it was my last login yesterday. Now I are again in the backend, but do nothing currently, because I see, also you are in the backend and I don't know what you are try.forgive me for writing you again, I just wanted to mention that yesterday when I checked the installation I saw that kunena was succesfully installed but today it was gone again.....why so ?
I've now installed a clean Kunena 5.1.10.1 on my test page, and the Kunena tables exported and the prefixes adjusted for your page.
Please check your E-mail, I've send it to you.
Delete all Kunena tables from your page and import this tables. Then try to install Kunena 5.1.10.1.
