Use this category:
Solved installation error
7 years 6 months ago #209579 by martinsai
Replied by martinsai on topic installation error
sry I saw yr message just now. How can i enable email message?
to your points:
1. There was no Kunena installed before. Just today i deinstalled everything of kunena, even in database I deleted all kunena tables but still same error. after i reinstalled kunena but still same error
2. It was Joomla 3.9.4.
3. Joomla worked fine including many extensions, just kunena, my last step in this project - did not work for a second.
7 years 6 months ago #209580 by rich
Replied by rich on topic installation error
Ah.. thats very helpfull. So you have no problem when I remove completely Kunena (via backend Kunena tools) and try again a installation.
But maybe I found already the problem (not sure), I need to check it.
7 years 6 months ago #209581 by martinsai
yes you can remove kunena completely, no prob!
7 years 6 months ago - 7 years 6 months ago #209582 by rich
Yes, I think I found the problem. Seems to be a wrong server setting. Go in backend to "System -> System Information -> tab PHP Information".
Press Strg + F and search the entry memory_limit
In your PHP Setting shows
memory_limit = -1
but it should be
64 Mb or even 128 Mb (minimum is 32Mb I think)
Unfortunately that also does not work. Please remove the Kunena tables again manually. Then check in the server setting the memory limit please.
Last edit: 7 years 6 months ago by rich.
7 years 6 months ago #209626 by martinsai
Dear Rich,
I did as you wrote: I enabled memory limit to more than 500 MB. see 2019.psychoanalyse-muenchen.de/phpinfo.php
I deleted allt ables in databse and deinstalled firstly kunena completely but still same error as above.
7 years 6 months ago #209627 by martinsai
I tried now version 5.1.6 but same error message
