Use this category:
Solved installation error
7 years 6 months ago #209468 by martinsai
Replied by martinsai on topic installation error
????? no help??????
7 years 6 months ago #209473 by rich
Replied by rich on topic installation error
martinsai wrote: ????? no help??????
We work already during our leisure time without getting something for it. Still you expect, that we on weekends also always are available?
yes, without any problems. can I give you access to the website?
I can take a quick look, but can not promise that I find the problem. Have you a full backup? Better would be a test page with a clone of the page.
You can send the access data to rich@*kunena.org (address withouit star).
7 years 6 months ago #209476 by rich
rich wrote: Please go to the Joomla Global Configuration (tab Server) and set Error Reporting to Maximum. Then the error message should be more exact.
I'm sorry, it was my mistake. I forgot to write, you must also enable the Joomla debug mode so that it shows a error message.
7 years 6 months ago #209521 by martinsai
thnx, if you find error plz send me a small invoice, I will pay. i will contact u through mail, thnx
7 years 6 months ago #209523 by rich
You need not pay for me, the Kunena project is free, also the support here in this forum.
The last version which is possible to install is Kunena 5.1.6, newer versions are not possible. But it shows no categories in the category manager and in the Kunena user list you get this error: Notice: Undefined property via __get(): banned in /libraries/kunena/user/user.php on line 2170
My questions now:
1. Which Kunena version was installed before you tried the upgrade.
2. Which Joomla version was installed before
3. With which versions (Joomla and Kunena) it has worked as expected
7 years 6 months ago #209578 by martinsai
ok, I enabled the debug moide and the maximum error message.
it is so many content, I hardly can send u everything via attachment. I gave you access via mail. can you check?
