Use this category:
Question Kunena Forum not found (class)
- 53e437eb2fd79d469d4f37b8
- Banned
The important thing is that there is no issues.
- Banned
Thank you for reporting. The plugin has a dependency on Kunena.
To avoid the message during installation of Kunena, we recommend disabling the plugin in the process to upgrade, or simply ignore it until the installation is completed.
We can't remove it since it prevents the execution of the plugin when Kunena is no longer installed.
Best Regards,
sharing = caring
- anibal.sanchez
We can't remove the checkup since it prevents the execution of the plugin when Kunena is no longer installed.
Best Regards
These add no value (other then visual messages on both back-end and front-end).
file: ./plugins/system/autotweetkunena/autotweetkunena.php
sharing = caring
