Use this category:
Question Kunena Forum not found (class)
- anibal.sanchez
Yes, that's where the warning message that we are currently showing.
In the future, we'll replace the JError call with JFactory::getApplication()->enqueueMessage ..., but the warning message will remain since we need to alert users when the plugin is enabled and Kunena is no longer installed.
Best Regards,
just for the sake of argument: I am the user. I have had this message already for a long time. I had no clue as to what it means and what it does / doesn't do. So I just crossed my fingers and ignored it. It turns out now that ignoring is good as nothing breaks.
That is why I say that the messages are useless
To make it 'worse', the message also shows on the front end. Therefor it is not only showing to me (in the back-end) but to every user who knows even less what these messages mean.
The message is also logged into the log files, I think that should be enough.
If you want to keep the visual warnings: please make them so they are actually informative. Restrict them to showing up on back-end only. Tell the user something like: "The Autotweetplugin requires Kunena to be installed and enabled. If you are updating Kunena you can ignore this message"
You could even extend you component check page: Plugin enabled but component not found indicator.
just my 2ct
sharing = caring
- anibal.sanchez
Regards,
Anibal
it's the latest 4.0.10 of kunena, Bluestacks TextNow Photomath
- Thank you received: 2545
If you have a question, then update your page previously and create a own topic.
- anibal.sanchez
As I said before, the warning message is necessary. It's just a warning shown at the moment that Kunena is not available while the extension is being updated.
The message is required since it also warns the administrator when Kunena is uninstalled and the integration plugin for Kunena is still enabled.
Hope this helps! Let us know if there is anything else we can do.
Best Regards
