Solved Crypsis Module Positions & Uploads not working properly
This is what I understand you to have written.810 wrote: [The] bug ... was the module [position that didn't appear in K 4.0 Crypsis. We] have fixed that in the [latest/K 4.0.10] version.
Well, I know that you and I sometimes disagree about the definition of a bug (or defect or "issue") but I don't think this makes people happy to read that, on the one hand, K 4.0 allows module positions (in the form of kunena_msg_n) to accommodate placement of modules at every nth message for Blue Eagle but does not allow it similarly for those who use Crypsis.810 wrote: What Rich found has nothing to do with a bug/issue but a feature request.
Therefore, by saying that people need to "customise their Kunena template" (without providing any tutorial or documentation about the procedure and in the knowledge that these "customisations" will inevitably fail in future when the internal structures in Kunena are changed ) I don't agree with your assessment that this module position issue is not a defect as you have tried to characterise it.
It is clear from looking at GitHub #3687 that this is a bug. At the time of writing #3687 is classed as a bug and that was why I wrote earlier that this topic should be moved to a different category.
All very confusing. It doesn't inspire confidence if people cannot use Kunena in a "similar" kind of manner whether they use Crypsis or Blue Eagle. Leaving that aside, to summarise what you've written: if you want to use Kunena to place modules after every nth message posted (relative to the top of the page) use Blue Eagle; this feature is not supported in Crypsis. Crypsis allows the use of module positions at the nth absolute position (relative to the first message posted in a topic) but does not repeat if a topic spans more than one page.
If I may also summarise my understanding of what has been written, the ability to use relative module positions in Crypsis—in a similar way to how things have worked with the older (Blue Eagle) template dating all the way back to K 1.6—is considered by the development team to be a feature request.
I stand corrected. 5 minutes after writing this, rich changed the classification of the issue to "feature".sozzled wrote: It is clear from looking at GitHub #3687 that this is a bug. At the time of writing #3687 is classed as a bug and that was why I wrote earlier that this topic should be moved to a different category.
In spite of this, I don't think it changes my assessment of what this topic is discussing and it hasn't helped GizChris one bit by debating the matter. I think most people would agree that this matter is a significant shortcoming in Crypsis—for those who want to use module positions—and something that should be addressed quickly.
@GizChris: This shortcoming with the module position will not be fixed in K 4.0 Crypsis. End of story, I think.
