Solved Crypsis Module Positions & Uploads not working properly
10 years 9 months ago - 10 years 9 months ago #173125 by GizChris
So the module positions do now work after the recent update but file uploads still don't work.
Edit: Actually module positions still do not work properly. It still doesn't display after the fourth post on EVERY page inside a topic like it once was the case, now it displays after post number four in any topic. And topic list module positions still don't work at all.
Last edit: 10 years 9 months ago by GizChris.
10 years 9 months ago #173126 by 810
this has always been this way. It can only be set on fixed module positions, else you need to edit the template, then you can customize it to your needs.
10 years 9 months ago #173132 by rich
hmm.. I see now what GizChris means. Before this fix the module was displayed by post ID. Now it is the absolute message number in a topic. But it should be message number per page.
Example kunena_msg_1 : The module will displayed only after the first message in a topic. If you go to page 2 there is nothing.
I will create a issue for it.
The following user(s) said Thank You: GizChris
10 years 9 months ago - 10 years 9 months ago #173133 by sozzled
This topic was originally posted in the K 4.0 General Questions category.
rich wrote: Before this fix (sic) the module was displayed by post ID. Now it is the absolute message number in a topic. But it should be message number per page.
If people would like to follow the progress on this issue, they can go >>> here <<<
It seems that this is actually a defect of K 4.0 Crypsis. It may be better to move this topic to the Kunena Support (reporting defects) category, yes? :)
Last edit: 10 years 9 months ago by sozzled.
10 years 9 months ago - 10 years 9 months ago #173134 by sozzled
GizChris wrote: I stumbled upon another issue with Crypsis. Uploads do not work anymore with it. If I try to upload something it just says "upload failed". Permissions are set correctly (755) and it works flawlessly when I switch back to Blue Eagle.
810 wrote: this is a bug, we are still looking for a fix.
I am not sure which "bug" 810 is talking about but, perhaps, he means >>> this <<<?
rich found a defect in the way that Kunena handles module positions. Until rich reported this problem, I was not aware of an item in GitHub that refers to it. 810 wrote about a "bug". I assume that he's referring to a problem with uploads.
It looks like this topic discusses two separate problems and it's difficult to follow the progress in resolving two different problems if they're mixed together. I suggest that the subject of the topic in the first post be changed to refer only to the module positions and let's stay on-topic with that issue. The question about the upload problem is better discussed elsewhere.
It would be good if one of the developers can provide an update on the situation with the "failed upload" problem (810 wrote that it's an "old Joomla bug") and how it's being addressed.
In any event, it is clear that this is not just a general "how to" question. We're talking about a defect (or two) and the topic should be moved to the appropriate category.
10 years 9 months ago #173135 by 810
Bug what i talk about, was the module doesn't showed at all, we have fixed that in the lasted version. see: github.com/810/Kunena-Forum/commit/c0e88...a662dfe58f238aec8829
What Rich founded has nothing todo with a bug/issue. But a feature request.
kunena_msg_5 means after message 5 of the topic.
There is no default support to show it on each 5 messages.
Then you need to customize your kunena template.
