Solved Crypsis Module Positions & Uploads not working properly
10 years 10 months ago - 10 years 10 months ago #172376 by GizChris
Hey guys,
I just switched to Crypsis and I face a problem with module positions. I used to display banners after the fifth post in category lists and after the fifths post in topic views. Anyway, that's not possible anymore. The Crypsis template doesn't display module positions as e.g. "kunena_msg_5" anymore but as "kunena_msg_{topicID}". Because of this I can only show a banner on one specific post, but not not after x post. Any idea on how to fix that bug?
All the best,
Chris
Last edit: 10 years 10 months ago by GizChris.
10 years 10 months ago #172380 by 810
mhh, i just tried it, and he is now on msg 3, not on five.
Need to check why, maybe he is set on real message number 5
10 years 10 months ago #172384 by GizChris
I don't know if you got me right. With the Blue Eagle template the kunena_msg_x module positions are independent from the topic ID. So in each topic and for each page you have module positions from 1 to 10 for example. With the Crypsis template however that is not the case anymore. The digit after msg_ equals the message ID. That mens I can not set a banner after the 5th message on each page of a topic anymore. If I set a banner with the position kunena_msg_5 for example, it will ONLY be displayed on the message with the ID 5. Or is I go for 160, it will be after message 160.
Furthermore I stumbled upon another issue with Crypsis. Uploads do not work anymore with it. If I try to upload something it just says "upload failed". Permissions are set correctly (755) and it works flawlessly when I switch back to Blue Eagle.
10 years 10 months ago #172385 by 810
which version are you on, could you add the kunena report:
backend - components - kunena - tools - report
10 years 10 months ago - 10 years 10 months ago #172432 by GizChris
I am on the latest version. Regarding the upload issue: I have seen other people facing the same issues!
htaccess: Exists | PHP environment: Max execution time: 180 seconds | Max execution memory: 128M | Max file upload: 512M
Joomla default template details : ts_newsline | author: Tripples | version: 2.1 | creationdate: Dec 2013
Kunena default template details : Crypsis | author: Kunena Team | version: 4.0.9 | creationdate: 2016-01-21
Kunena version detailed: Kunena 4.0.9 | 2016-01-21 [ London ]
Third-party components: UddeIM 3.7
Plugins: None
Modules: Kunena Latest 3.1.2.1
10 years 10 months ago #172481 by GizChris
Time to create page: 0.151 seconds
