Solved How can I change category and topic icons in Kunena 4.0.7 ??
ventluc wrote:
810 wrote: for Categories (only crypsis):
- open the category manager - edit category - enter css class for icon
Can you explain me better? I mean:
1) If I have understood well do I need to create a new css class for icon? Am i right? If yes, in which file must I put the new css class? How can I set the new css class in the category manager? Where can I find the default css class so that I can modify it?
2) How can I change category icons for Blue Eagle template?
810 wrote: for topic icons:
- open the category manager - edit category - edit topic icons*
*icons + xml should be in media\kunena\topic_icons\your_custom
A question: in the category manager I haven't a section for the topic icons!!! Which section do you refer to?
Thanks a lot,
Luca
CAN SOMEONE REPLY TO MY QUESTIONS ABOVE, PLEASE? I NEED AN ANSWER FOR EACH OF THEM THAT SHOWS ME A SOLUTION THAT WORKS!!! IT IS INCREDIBILE THAT SUPPORT TEAM OF KUNENA DIDN'T WRITE A MANUAL TO MODIFY CATEGORY'S ICONS AND TOPIC'S ICONS!!!
- Thank you received: 2538
If you are using a Joomla template which supported bootstrap icons, is it even easier.
Here a example with template Protostar and Crypsis.
Enter the name of icon in the category manager such as icon-home, icon-trash etc.. That's all.
Here is a list with this icons.
The same works also with Blue Eagle but it needs a little CSS customization.
Go in backend to "Kunena -> Templats -> mark Blue Eagle -> Edit CSS -> custom.css -> Edit CSS" and enter this codes:
a) to create my own icon and associate it to a category: that is to say, for example, that I want to create a .png or jpg icon (for example: heart.png - 32x32 px) and associate it to the category "Love" in my forum (that uses Blue Eagle template);
b) I would like to do the same thing described above for each topic;
I WOULDN'T LIKE TO USE PREDEFINED ICONS OF KUNENA. So what you told me makes no sense! In fact:
a) You told me "Enter the name of icon in the category manager such as icon-home, icon-trash etc..": what does it mean? Is the "name of icon" that you refers to the name of the file of the icon without extension (for example if I have heart.png I should insert "heart" in that field??) ??? If not, how can I associate the name of my icon to its file (eg. "heart" (or I can choose also "love" for the name of the icon) to heart.png)?
b) In the case of "Blue Eagle template" you told me that I must modify the custom.css: but where must I insert the name of the image file of the icon (eg. heart.png)? And where must I put the name of the icon associated to heart.png?
c) How can I do the same thing for the topics of each category? I mean: if I would associate my own icons to topics of a particular category of the forum which steps should I follow? You didn't talk about this in your post...
Thanks a lot.
Luca
Sorry, but I think you didn't understood my problem! I would like:
Here with more details the same in German language: www.kunena.org/forum/36-German/125164-ge...orien-aendern#134091rich wrote: It's a old tutorial but it still works with Blue Eagle. The only difference is that the image *_notlogin.gif is no longer needed.
I'm sorry, I know no way.b) I would like to do the same thing described above for each topic;
I need to know an answer to my questions in italian or english language
This is in English language and it works with Blue Eagle.rich wrote: It's a old tutorial but it still works with Blue Eagle. The only difference is that the image *_notlogin.gif is no longer needed.
That's not possible. You can replace the existing topic icons, but these are selectable for topics in all categories.b) I would like to do the same thing described above for each topic;
