Solved How can I change category and topic icons in Kunena 4.0.7 ??
10 years 9 months ago #171798 by 810
and what are the options on edit crypsis template. Is the option on Topic Icons= Fontawesome?
10 years 9 months ago #171799 by loppan
810 wrote: and what are the options on edit crypsis template. Is the option on Topic Icons= Fontawesome?
Yes, Topic Icons = Fontawesome, and "Load External CDN Fontawesome" is "No" because I'm already loading it in my template... setting it to "Yes" does not help :/.
10 years 9 months ago #171800 by 810
and what is the option at configuration - frontend - Selectable Topic Icons = Yes?
10 years 9 months ago #171801 by 810
or try this:
libraries / kunena / template / template.php line 977
change:
$icon = 'file';
to:
$icon = 'newspaper-o';
The following user(s) said Thank You: loppan
10 years 9 months ago - 10 years 9 months ago #171822 by loppan
810 wrote: or try this:
change:
$icon = 'file';
to:
Wow! So glad to find out where to change this :). Now the icon I put there is shown by default in every category.
Wouldn't we want to change this behaviour, so it picks the icon from my icon-set xml file for each category instead?
810 wrote: and what is the option at configuration - frontend - Selectable Topic Icons = Yes?
Wow (again), couldn't find this setting before, so far I've removed some code from "crypsis//layouts/topic/edit/default.php" whenever I don't want to show the topic icons. Good to know there is a simple switch for it :). Either way, it's set to yes.
So, here's where we are :
1. When writing a new topic - or modifying a current topic - the topic icons that I have defined in "media/kunena/topic_icons/default/topicicons.xml" are showing, just like they should.
2. Old topics still pick there icon from libraries/kunena/template/template.php "$icon = 'file';"
(btw, it was line 949 here at my end - don't know if it makes a difference...)
Do we have a simple fix for having Kunena listen to the xml-file at all times instead? It would obviously be nice to be able to display different topic icons in different categories, even for older threads :).
Many thanks for your help 810, truly appreciate it!
Best
Peter
Last edit: 10 years 9 months ago by loppan.
10 years 9 months ago #171825 by 810
I will change the code for K5.0, so you need to wait for it. Best for now just change the code, until its fixed.
