Kunena 7.0.8 Released
Solved How can I change category and topic icons in Kunena 4.0.7 ??
I have installed Joomla 3.4.5 and Kunena 4.0.7 forum. In Kunena I would like to change icons of my topics and categories for both Blue Eagles and Crypsis templates (for example I would like to use an heart icon for the category "Love"), but I don't know how to do it!! About this issue in this forum I found only old posts related to old versions of Kunena or with broken links....have someone more updated information to solve this problem?
Then I have another question: if for the front-end (for both Blue Eagles and Crypsis templates) no specific icon is associated to each category ( icons are used only for the topics). In fact if I use the above templates Kunena shows only a text label to specify a category: so how could I associate an icon for each category too?
Thanks a lot.
Luca
- open the category manager - edit category - enter css class for icon
for topic icons:
- open the category manager - edit category - edit topic icons*
*icons + xml should be in media\kunena\topic_icons\your_custom
810 wrote: for Categories (only crypsis):
Can you explain me better? I mean:
1) If I have understood well do I need to create a new css class for icon? Am i right? If yes, in which file must I put the new css class? How can I set the new css class in the category manager? Where can I find the default css class so that I can modify it?
2) How can I change category icons for Blue Eagle template?
810 wrote: for topic icons:
A question: in the category manager I haven't a section for the topic icons!!! Which section do you refer to?
Thanks a lot,
Luca
ventluc wrote: A question: in the category manager I haven't a section for the topic icons!!! Which section do you refer to?
Thanks a lot,
Luca
Categories / Edit Category / Category settings tab, at the bottom. Find it?
However, I still cannot get this to work, truly grateful if someone could point out what I'm doing wrong
I'm using crypsis with fontawesome.
Let's say I'd like to change the default topic icon for my "News"-category. I have selected "Default" in the "Topic Icons" setting above, so I go edit media/kunena/topic_icons and change row 15 :
<icon id="0" name="default" published="1" b2="file" b3="file" fa="file" title="COM_KUNENA_ICON_DEFAULT" src="user/default.png" />
to :
But when I view my category in the frontend, the previous default topic icon is shown :
Using Chrome Developer it says that the icon class is fa fa-file fa-2x. Where is this defined?
Best
Peter
- antonio123
Can you elaborate? I’m also trying to figure this out.
