Solved Banner users or deleted users problem - Users think their account is being hacked
11 years 5 months ago #166215 by carlat2
Hi, I tried (TOOLS OPTION) no change.
I also switched to the default template, no change.
Any other ideas?
11 years 5 months ago #166239 by xillibit
Can-you put please your Kunena report configuration settings ?
11 years 5 months ago #166292 by carlat2
htaccess: Missing | PHP environment: Max execution time: 1000 seconds | Max execution memory: 1024M | Max file upload: 200M
Joomla default template details : jm_omnia | author: JoomlaMan.com | version: 2.2 | creationdate: Unknown
Kunena default template details : JF Social | author: JoomForest.com | version: 2.1 - k 3.0.3 | creationdate: 01.12.13
Kunena version detailed: Kunena 4.0.1 | 2015-06-10 [ Alto ]
Third-party components: Jomsocial 4.0.7
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.7 | JomSocial - My Kunena Forum Menu 3.2.1.5 | JomSocial - My Kunena Forum Posts 3.2.1.5 | JomSocial - Kunena Groups 3.2.1.5
Modules: Kunena Latest 3.0.1 | Kunena Login 3.0.1
11 years 5 months ago #166301 by 810
try to disable AlphaUserPoints .
and look if its still loaded
11 years 5 months ago #166307 by carlat2
What does it have to do with the avatar change? (Alphauserpoints?)
11 years 5 months ago #166308 by 810
you have set to load 3 different plugins the avatar functions, so maybe there is a conflict, with opening the right profile avatars
- Alphauserpoints
- jomsocial
- Kunena
So go to Alphauserpoints plugin and disable the avatar option, same on the kunena plugin.
Time to create page: 0.159 seconds
