Solved Banner users or deleted users problem - Users think their account is being hacked
11 years 5 months ago #165328 by carlat2
In my forum banned user post appear with the picture of the users who's viewing the topic so it causes confusion since all the user think their pics are user for fake accounts.
It doesn't appear any user name just the comment of the banned user appear with the current user photo who's reading the msg.
Is there any way to solve this?
11 years 5 months ago #165329 by carlat2
an image of what happens with the banned members posts:
11 years 5 months ago #165525 by 810
did you tried the default template, or the new crypsis template?
11 years 5 months ago #165970 by carlat2
11 years 5 months ago #165971 by 810
The joomla template has a kunena override on the template.
So I suggest to do this:
1) Make backup database and files.
2) Go to /components/com_kunena/template/jf_social/css/
3) remove all kunena files
4) Go to /components/com_kunena/template/jf_social/html
5) remove com_kunena dir
6) Uninstall kunena (data will not be removed) by the joomla extension manager
7) Install kunena K4.0.1
8) Set Crypsis as default
If its good, the kunena will have your joomla template colors like the pink.
11 years 5 months ago #165978 by 810
What you also can try first:
1) backend - kunena - tools - Synchronize Users - select all options, select sync.
2) select recount statics- click on recount statics
