Solved Banner users or deleted users problem - Users think their account is being hacked
11 years 3 months ago #167658 by carlat2
I HIRED SOMEONE, he told me he couldn't find the answer.
IF someone here is willing to do it for a price, just tell me and the problem is solved. I'll be glad to post the solution for all the kunena users that have the same problem.
regards,
11 years 3 months ago #167659 by sozzled
I do these kinds of things on a daily basis, every day. If you want to delete certain messages from the database, that's easy. The solution may be as simple as deleting certain offending messages.
As we all know, it can be disastrous to delete accounts from the Joomla user table — you've already discovered one of the consequences of that action. Some years ago, the Kunena team issued warnings to not delete user accounts. People didn't take that advice and it causes problems. The problems can filter through to JomSocial, AlphaUserPoints and other components that originate from the Joomla user table. What needs to be done is to get everything back into synch.
I will work with you for as long as it takes to fix the problem. Just about knows my business and whether I might be a reliable choice or not; therefore I will leave the matter in your hands to decide what you want to do next.
The following user(s) said Thank You: xristo
11 years 3 months ago #167660 by xillibit
carlat2 wrote: I disabled anything with POINTS on it it didn't work.
Can I have a query to delete all the messages done by an banned user of by a non existant user?
All my users are going crazy thinking that their accounts are hacked.
Do-you have tried to disable entierely the plugins AUP and Jomsocial for integration ?
The query to delete message done by an user identified by an userid is :
DELETE FROM #__kunena_messages AS m #__kunena_messages_text AS text ON text.mesid=m.id WHERE m.userid=XXX
Make an entire backup of database before to execute this query, replace XXX by the userid of user
11 years 3 months ago - 11 years 3 months ago #167680 by sozzled
xillibit wrote: The query to delete message done by an user identified by an userid is :
As fxstein, the co-founder of the Kunena project, pointed out a few years ago :
Unless you are a Joomla, Kunena AND SQL expert, you MUST NOT run SQL quieres against your install database by hand.
A single typo can and will have the potential to damage to drop portions or all of your data and WILL render you system useless. Most ALTER, INSERT, UPDATE, DELETE, DROP statements cannot be undone. Once executed and something goes wrong data is lost forever. Only way back: Restore from your backup
I realize that people want to help each other with SQL queries 'fixing' underlying problems. in most cases the problem you see is a side effect from another problem or upgrade or migration.
If that is the case get an expert (free or pay for it) to do it for you.
Even the best most accurate SQL statement written for one specific problem, used out of context, against a different version can be fatal.
Just today I witnessed a thread in which somebody carelessly copied some SQL statements around as a 'fix' and by accident, forgot to copy the entire statement, dropping one rather important part of the query.
SQL statements and myphpAdmin are not for novices. Not in Kunena, not in Joomla or any other system you want to keep using.
We will advise all our team members going forward to not post any such 'solutions' on the public forum.
Please note that the syntax of the SQL statement given by xillibit is incorrect, it produces the following error if you attempt to run it with phpMyAdmin
and it probably will not resolve your particular problem
Last edit: 11 years 3 months ago by sozzled.
11 years 3 months ago #167687 by xillibit
DELETE m FROM #__kunena_messages AS m INNER JOIN #__kunena_messages_text AS text ON text.mesid=m.id WHERE m.userid=xxx
You should notice that to make working this query you need to set your own prefixes in the query
11 years 3 months ago - 11 years 3 months ago #167697 by sozzled
xillibit wrote: Make an entire backup of database before to execute this query, replace XXX by the userid of user
As people will see (when they compare the above example with the previous-written example) the two examples of this generalised SQL statement are different. In both cases these statements will cause syntax errors and, in both cases, they may not be a complete solution for the problem as stated in the original post.
The point that I am trying to make here—the point that Oliver Ratzesberger made 5½ years ago—is that it is dangerous for people who do not know SQL or how to properly use phpMyAdmin to use examples of SQL statements posted on any forum and apply them to their [unique] purposes.
In cases where it may be necessary to directly modify data in the Joomla database tables these are probably best left in the hands of experts.
Yes, it is true that the SQL syntax needs to be changed to use one's own table prefixes. The example does not show where or how this should be done. I will not comment further about this suggestion except to say that, in the hands of novices and those people unfamiliar with SQL, it is probably better to let a professional perform these kinds of activities (on a copy of an existing website) instead of trying to do it oneself (and making a total mess of things). B)
Last edit: 11 years 3 months ago by sozzled. Reason: minor change to subject
