Question CKeditor
2 years 11 months ago #230300 by HanKortekaas
Replied by HanKortekaas on topic CKeditor
I also like the SCEditor better, but it is not yet fully integrated (e.g. smileys, or insert images in messages do not work).
I found that one can insert images, but you don't see it instantly. Only after posting it shows.
And SCeditor also has items for twitter, instagram and the like which I don't want.
Han
The following user(s) said Thank You: Ratman
2 years 9 months ago #230872 by Ratman
Replied by Ratman on topic CKeditor
I've tried to figure out where the SCEditor configuration is stored, but with not much success. When I use the browsers developer tools, I can see that the SCEditor searches for emoticons in the wrong path ".../media/kunena/emoticons/emoticons". I created a new folder "emoticons" inside the /media/emoticons folder and copied the complete emoticon files into this folder, but the SCEditor shows only some (default?) smilies in the dropdown menu. So I wonder where is the list of emoticons that SCEditor wants to load?
And where can I configure the toolbar, e.g. which buttons should be shown and which not?
Yes, I know that the SCEditor is not yet fully integrated into Kunena and the Devs sure are working hard on this topic. But the problem is that the CKeditor is not usable anymore since the last update, so I was forced to switch to the SCEditor. But as this is still not completely usable, I can see that more and more of my users are keeping away from my forum. The number of posts is rapidly decreasing which is twice as hard for me, because it is a small niche forum.
So any hint is highly appreciated!
Thanks a lot in advance!
2 years 9 months ago #230874 by Pinkeltje
Replied by Pinkeltje on topic CKeditor
What is your problem with CKEditor? In my forum it works perfectly with Joomla 4.4.3 and Kunena 6.2.4
2 years 9 months ago - 2 years 9 months ago #230875 by Ratman
The problem with CKEditor was discussed here -> www.kunena.org/forum/k-6-2-0-support/168344-no-editor-showing
Strange thing is that it does not hit all users of my forum, but many of them.
Last edit: 2 years 9 months ago by Ratman.
2 years 9 months ago #230876 by rich
Replied by rich on topic CKeditor
How many languages do you have installed in Joomla? Navigate to /media/kunena/core/js/lang/ and check if there are the same number of script files. For each language installed in Joomla there must be a corresponding script.
2 years 9 months ago #230877 by Ratman
Hi Rich.
There are two languages installed in Joomla, english and german
And so are the languages for CKEditor
Time to create page: 0.145 seconds
