Question CKeditor
2 years 9 months ago - 2 years 9 months ago #230892 by Ratman
Replied by Ratman on topic CKeditor
Sorry, I uploaded the files from my PROD stage. This is where some of my users witness the empty editor issue, but I cannot reproduce it by myself.
I just visited the lang folder in my STAGE site, and here only the english language file exists. I don't know why. Here is the ZIP with the stage language file:
File Attachment:
File Name: lang_stage.zip
File Size:4.83 KB
Last edit: 2 years 9 months ago by Ratman.
2 years 9 months ago #230893 by Ratman
The files are ok. How do you reproduce the error, since you had written that this error occurs for some users, but the editor works for you? I cannot reproduce this error, only a similar one when I remove or rename these plugins.
On my PROD site I cannot reproduce the error, but some users sent me screenshots where I could see the empty editor. With my own accounts (admin and a normal user) everything works well.
On my STAGE site I have a test account and I can reproduce the issue with it.
2 years 9 months ago #230894 by rich
Replied by rich on topic CKeditor
This zip file only contains the English language script. If several languages are installed in Joomla (in your case English and German), these language scripts must also be present in the "lang" folder.
But I think I have found the error. Have you ever created a customckeditor_config.js to change the language? If so, then comment out the code CKEDITOR.lang.languages={"en":1, "de":1}.
From
to
// CKEDITOR.lang.languages={"en":1, "de":1}.
2 years 9 months ago #230895 by Ratman
No, there is no such line in my customckeditor_config.js , neither in the STAGE (see attachment) nor in my PROD site.
I just copied over the DE language file from the PROD to STAGE, but it did not change anything :(
File Attachment:
File Name: customcked...nfig.zip
File Size:1.23 KB
2 years 9 months ago #230898 by Pinkeltje
Replied by Pinkeltje on topic CKeditor
Did you try with Aurelia template?
I see you are using NTS Kunena template. Do you have the latest version?
I use an NTS Kunena template that still hasn't been updated to Kunena 6.2.4 unfortunately and discovered that in contrary to what rich said earlier CK editor isn't working if I disable
in customckeditor_config.js
When switching to Aurelia without custom editor file, CKEditor is working like expected.
So it might be template related.......
2 years 9 months ago #230900 by Ratman
Thanks a lot for this hint.
Switched to the Aurelia template, now on my STAGE site the issue is gone! I downloaded the latest version of the NTS KBee template, CKEditor is still working!
Let me check this on my PROD site, I'll keep you informed.
