Topics must relate to a currently supported version of Kunena. If you are unsure what is the current supported version of Kunena, please go to the
download
page.
Question CKeditor
2 years 9 months ago #230883
by xillibit
This two things aren't yet implemented into the integration of SCeditor into Kunena
If ou have a test site or an account on your site to try
Hello,I've tried to figure out where the SCEditor configuration is stored, but with not much success. When I use the browsers developer tools, I can see that the SCEditor searches for emoticons in the wrong path ".../media/kunena/emoticons/emoticons". I created a new folder "emoticons" inside the /media/emoticons folder and copied the complete emoticon files into this folder, but the SCEditor shows only some (default?) smilies in the dropdown menu. So I wonder where is the list of emoticons that SCEditor wants to load?
And where can I configure the toolbar, e.g. which buttons should be shown and which not?
Do-you have something displayed into the javascript console when this issue happens ? Do-you know for your users which have not changed the language in their Joomla! profile settings ? Or they have set a specific language ?Yes, I know that the SCEditor is not yet fully integrated into Kunena and the Devs sure are working hard on this topic. But the problem is that the CKeditor is not usable anymore since the last update, so I was forced to switch to the SCEditor. But as this is still not completely usable, I can see that more and more of my users are keeping away from my forum. The number of posts is rapidly decreasing which is twice as hard for me, because it is a small niche forum.
So any hint is highly appreciated!
Thanks a lot in advance!
2 years 9 months ago #230884
by Ratman
Okay, but where does the SCEditor take the path ".../media/kunena/emoticons/emoticons" take from?
I have a test site and an account where I can reproduce the issue. I will take a look into the Javascript-Console. I already tested if the issue has something to do with the preferred Joomla language, but the issue occurs always, no matter if I choose "Default", "English" oder "German".
- Thank you received: 2545
2 years 9 months ago - 2 years 9 months ago #230890
by Ratman
Here we go...
Edit: Sorry, wrong files, please ignore!
Last edit: 2 years 9 months ago by Ratman.
2 years 9 months ago #230891
by rich
The files are ok. How do you reproduce the error, since you had written that this error occurs for some users, but the editor works for you? I cannot reproduce this error, only a similar one when I remove or rename these plugins.
