Question CKeditor
2 years 11 months ago #230259 by HanKortekaas
CKeditor was created by HanKortekaas
Where do I find the language files for CKeditor . All of the translations into Dutch are missing.
Han
2 years 11 months ago - 2 years 11 months ago #230268 by rich
Replied by rich on topic CKeditor
These language files are somewhat difficult to find. Go to this website and scroll down.  ckeditor.com/cke4/builder
Move the desired language into the left field and download the zip file.
Open this zip file and search for the folder "lang", which contains the language file. Then follow these instructions: docs.kunena.org/en/faq/ckeditor-configuration
Last edit: 2 years 11 months ago by rich.
2 years 10 months ago #230289 by HanKortekaas
Replied by HanKortekaas on topic CKeditor
Rich,
thank you. I'm afraid I massed up the original Kunena maps/files by trying to get it to work.  So I switched over to the more simple Sceditor.
Han
2 years 10 months ago #230296 by Pinkeltje
Replied by Pinkeltje on topic CKeditor
Install Kunena again to restore your original files and folders.
2 years 10 months ago #230298 by rich
I also like the SCEditor better, but it is not yet fully integrated (e.g. smileys, or insert images in messages do not work).
2 years 10 months ago #230299 by Pinkeltje
Smileys do work in sceditor but you have to create a new folder emoticons in the folder emoticons and put/copy them in that folder. There is something wrong with the path in the code.
