- Thank you received: 2538
Question What kind of topic
Confirmed, it's a bug.
@Bouma
You can use for each single category 10 different selectable topic icons. That's not enough?Bouma wrote:
rich wrote: @ruud
In the original files are the topic icons and labels with IDs 5, 6 and 7 comment out. If you edit this lines, you can use additionally (or instead of other symbols) these icons and labels for your own categories.
This is actually what I did on my side. But, if you want to ADD new icons, extra to the existing one, you need to edit somewhere else, which is like HTML, and until now, I have no clue where to add some html lines in the blue_eagle5 template.
rich wrote: @ruud
@BoumaYou can use for each single category 10 different selectable topic icons. That's not enough?Bouma wrote:
rich wrote: @ruud
I'll need to look further the way you explain it. Cause I can make the IDs 5,6,7 to show. Can you confirm that all this will also work with the "blue_eagle5" template? the one that Kunena sell.
rich wrote: @ruud
fix? please test
[strike]also, where can I change the class on the locked label / badge? Want to change the class because the red is to... red
EDIT: Never mind... hard coded
sharing = caring
It needs no own class. The label Locked is a system label and will only used for locked topics.[strike]also, where can I change the class on the locked label / badge? Want to change the class because the red is to... red[/strike]
You have created little mistake, you use the same label type in your custom label.xml. Go to your customized labels.xml and rename the label type from important to implement (or similar). Then you have the extra class.
Example:
@Bouma
If you make all correct, then it works. But don't change sytem or template files otherwise you can destroy your page!
Top! 'fixed'rich wrote: It needs no own class. The label Locked is a system label and will only used for locked topics.
Thanks for helping out @Rich.
sharing = caring
