Question What kind of topic
  • rich
  • rich's Avatar Topic Author
  • Offline
  • Kunena Moderator
  • Kunena Moderator
  • I like sunshine and flowers
9 years 10 months ago - 9 years 10 months ago #182123 by rich
What kind of topic was created by rich
Our settings here on k.org are:
In "Backend -> Kunena -> Templates -> Crypsis -> Featues -> Show Labels = Topic id" (it shows the labels such as Solved etc...).
and in the "Configuration -> (tab) Frontens -> Selectable Topic Icons = No" (so can only moderators change the labels). The labels are selected with the topic icons.
Last edit: 9 years 10 months ago by rich.
  • rich
  • Offline
  • Kunena Moderator
  • Kunena Moderator
9 years 10 months ago - 9 years 1 month ago #182143 by rich
Replied by rich on topic What kind of topic
Yes, it's possible. you need a copy of the labels.xml. Path is "media/kunena/labels/labels.xml"
Paste this file in "components/com_kunena/template/crypsis(crypsisb3)/config" and edit the file.
Here a example:
1. Download the zip file and unzip it. It include 2 files (the xml files for the labels and a file with codes for the label colors).
2. Upload the labels.xml to "components/com_kunena/template/crypsis(crypsisb3)/config"
3. Paste the less codes in your custom.less ( see here )
4. Create language overrides for yor own text ( see here )
It are this language keys.
COM_KUNENA_LABELS_DISCUSSION *it's a new key and need a language override
COM_KUNENA_LABELS_CLOSED *it's a new key and need a language override
The rest is otional, you need only a override if you to want another text
COM_KUNENA_LABELS_IMPORTANT
COM_KUNENA_LABELS_QUESTION
COM_KUNENA_LABELS_IDEA
COM_KUNENA_LABELS_LOVED
COM_KUNENA_LABELS_SOLVED
COM_KUNENA_LABELS_MERGED
Note! The less-file contains all codes for labels, b2, b3 and Font Awesome icon colors. Copy only the section in your custom.less, which you want to use!
Here the result:
Last edit: 9 years 1 month ago by rich.
9 years 1 month ago - 9 years 1 month ago #194679 by Bouma
Replied by Bouma on topic What kind of topic
rich wrote: Yes, it's possible. you need a copy of the labels.xml. Path is "media/kunena/labels/labels.xml"
Here a example:
Point 3 and 4, the links give a 404. And any chance to have the info for the blue_eagle5 template as well? thanks
Last edit: 9 years 1 month ago by rich. Reason: Links corrected
  • rich
  • Offline
  • Kunena Moderator
  • Kunena Moderator
9 years 1 month ago #194683 by rich
Thanks for the hint. The links are now corrected (also in your message quote text).
9 years 1 month ago #194729 by ruud
Replied by ruud on topic What kind of topic
I can't get this to work.
I have copied the following file:
cp ./media/kunena/labels/labels.xml ./components/com_kunena/template/crypsis/config/
in ./components/com_kunena/template/crypsis/config/labels.xml I have for this purpose changed the following line (fa question-circle into car)
<label id="2" name="COM_KUNENA_LABELS_QUESTION" b2="question-sign" b3="question-sign" fa="car" labeltype="primary"/>
as you can see no 'car'
and also here no car
Documentation has me running circles... as it 'contradicts' instructions in this post
what am I missing?
sharing = caring
  • rich
  • Offline
  • Kunena Moderator
  • Kunena Moderator
9 years 1 month ago #194731 by rich
On your first image it shows the default topic icon "file" and his label has the id="0" (it's the default label when users not select another symbol). But you have changed the label with ID = 2. Therefore you see not the car.
Second question: You see your customized topic symbols in the editor, if you create the topic in a category, where your customized topic icons are allowed (Category Manager -> Category -> Category Settings -> Topic Icons: Own Icon folder).
Time to create page: 0.268 seconds
