Kunena 7.0.8 Released
Merged K 1.7 -> K 2.0.3 upgrade and now forum contents are "gone"
13 years 8 months ago - 13 years 8 months ago #137812 by sozzled
Last edit: 13 years 8 months ago by sozzled.
13 years 8 months ago #137848 by kalemanzi
If you login to the frontend, does your categories and posts appear suddenly?
I have the same problem after upgrading to 2.0.3 on a 2.5 site that was migrated earlier with jupgrade.
13 years 7 months ago #138207 by Webguy101au
I Have exactly the same issue. I ported a site with latest jupgrade, old forums were I think 1.7.4 or so, all seemed to be working fine, decided to do upgrade to 2.0.3, it mentioned that I am upgrading, make a backup (Which I do)
I upgrade and all topics and replies have been removed? Not checked users.
I read perhaps try 2.0.2, so I rolled back, some menu options were a bit screwy, but I can live with that.
So I then try 2.0.2, I even crossed my toes this time, same thing, no errors at all, but all topics and replies seem to have been removed?
Is there a fix for this at all?
Is all the material still really there, and it is just the counts screwed up? Hmmm, maybe I should check that.
Cheers
13 years 7 months ago - 13 years 7 months ago #138209 by sozzled
What information, specifically, do you require? Have you looked at Kunena 2.0.3 known issues ?
Counts screwed up? Have you tried recount category statistics in the backend?
Last edit: 13 years 7 months ago by sozzled.
13 years 7 months ago #138210 by Webguy101au
Ahh, the stuff was there, the sql command fixed it, sorry, back to your usual viewing....
13 years 7 months ago #138225 by snehal
Hi..
I have upgraded joomla 1.5 pack to 2.5 alone with Kunena forum. I have got all the categories after up gradation but not able to get the posts from the category. :(
Please let me know if any one get like this problem.
Thanks in advance
Regards
Snehal
Time to create page: 0.235 seconds
