- Thank you received: 1
Sticky Upgrade problems with K 1.x -> K 2.0.3 (and solution)
- BrainDrained
13 years 11 months ago - 13 years 11 months ago #137496
by BrainDrained
As many have already found out the upgrade from 1.7.2 [strike]or 1.7.3[/strike] to 2.0.3 does NOT work.
If you do the upgrade 1.7.2 to 2.0.1 it DOES work, then you can update to 2.0.3
I hope this saves a few from the disaster I went through yesterday.
BrainDrained
BrainDrained
Last edit: 13 years 11 months ago by sozzled. Reason: minor correction - there never was a version K 1.7.3
The following user(s) said Thank You: hoeschen
The topic has been locked.
13 years 11 months ago #137511
by hoeschen
Replied by hoeschen on topic Upgrade problems with K 1.x -> K 2.0.3 (and solution)
I can confirm this issue.
All topics are unapproved / access denied even for admins and the date is 42 years in the past.
If you approve the topics manually the messages are fixed and even the creation date is correct.
It does not seems to be a database isssue. At least not with the messages table. :evil:
13 years 11 months ago - 13 years 11 months ago #137512
by regdomain
Replied by regdomain on topic Upgrade problems with K 1.x -> K 2.0.3 (and solution)
Confirm, upgrade to 2.0.3 is a disaster.
Where to get kunena 2.0.1?
Last edit: 13 years 11 months ago by regdomain.
- Thank you received: 2545
13 years 11 months ago - 13 years 11 months ago #137519
by rich
Replied by rich on topic Upgrade problems with K 1.x -> K 2.0.3 (and solution)
All publicly released stable versions of Kunena are available at:
joomlacode.org/gf/project/kunena/frs/?ac...50&_br_pkgrls_page=2
Last edit: 13 years 11 months ago by rich.
13 years 11 months ago #137588
by regdomain
thank you very much!
13 years 11 months ago - 13 years 11 months ago #137590
by regdomain
FAILURE
Attempt to upgrade from kunena 1.7.2 to 2.0.1 caused access rights problem to all categories. By default now joomla.level is selected and access is settled to 1 or 2 as unrecognized authorization method. Could not be changed. Upgrade to 2.0.3 did not fix the problem.
I gueass this is because of the latest core or jomsocial installed.
