Sticky K 2.0 general menu issues
13 years 6 months ago #143771 by sozzled
G'day, Martin-123, and welcome to Kunena
I suggest that, in the first instance, you read Kunena Menu issues which generally solves nearly all of these these I-installed-Kunena-OK-but-it-doesn't-appear-on-the-frontend problems. ;)
The following user(s) said Thank You: Martin-123
13 years 5 months ago #145143 by zhenzar
I have set up a forum on my page www.tidensspil.dk , but even though I've made a menu item pointing to the forum, no matter what I do - It will just make the menu link point to the front page...
The link in the menu settings are: www.tidensspil.dk/index.php?option=com_k...iew=category&catid=4
Password can be given to any who are willing to help me with this issue.... :-/
13 years 5 months ago #145192 by xillibit
You have misconfigured the menu link item to the forum, you can read this doc : www.kunena.org/docs/Kunena_menu_issues
13 years 5 months ago #145198 by sozzled
Replied by sozzled on topic K 2.0 general menu issues
*** Topics merged ***
13 years 3 months ago - 13 years 3 months ago #147126 by Ugubriat
Hi everyone,
My Kunena forum (at luminosityconsulting.co.za/ ) has suddenly started working very erratically.
In particular, the "Forum" menu item in the Main Menu straight-out fails (i.e. "this web page is not available", as though I'd lost the internet connection) when it's set to be a menu item alias. It works when it's a copy of the Kunena "Forum" menu item.
The Kunena menu along the top of the Forum works fine, but links within the forum itself, e.g. to topics and replies, always fail in the manner described above.
This has happened very suddenly, and it mystifies me.
Any suggestions would be enormously appreciated!
My configuration report is attached.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 5242880
Joomla default template details : joomlage0058-brightfuture | author: Joomlage.com | version: 1.0 | creationdate: June 2012
Plugins: None
Modules: Kunena Login 2.0.4 | Kunena Search 2.0.4
Last edit: 13 years 3 months ago by xillibit. Reason: Put correctly report configuration settings
13 years 3 months ago - 13 years 3 months ago #147139 by Jiminimonka
[strike]You should upgrade your Kunena to version 3.0.1 (especially as you posted in the Kunena 3.0 support forum ;)).[/strike]
In the Kunena admin, go to Forum Tools and use the Menu Manager to restore the Kunena menu to its default settings. Most likely this is a menu issue, which would require a good understanding of how Joomla menus work.
Please read the FAQ.
Only one question per topic.
Last edit: 13 years 3 months ago by sozzled. Reason: Last two messages were posted in the wrong category.
Time to create page: 0.183 seconds
