Sticky K 2.0 general menu issues
13 years 5 months ago - 13 years 5 months ago #143745 by sozzled
Replied by sozzled on topic The Kunena 2.0 Menu
As a general guide to menu issues, see the article in the Wiki called Kunena menu issues. There are links posted in this topic that will give you the actual page reference.
If you are having problems because of a particular web browser, the problems are probably caused by your Joomla site template. Without seeing your configuration report, I'm just guessing.
Last edit: 13 years 5 months ago by sozzled.
13 years 5 months ago #143762 by Martin-123
I checked all technical requirements, including PHP settings, before starting,
I'm installing on a dummy (duplicate of my actual) site,
I'm trying to follow the instructions meticulously, (but obviously something's gone wrong...!)
I've installed Kunena 2.0.4 onto my (duplicated) existing Joomla 2.5.9 site www.scienceofconsciousness.com
I've followed the instructions re: reCAPTCHA and API key and renamed HTACCESS.txt to .HTACCESS
... but the forum isn't appearing anywhere on my front end. Don't I have to create a menu item within my site to point at Kunena? (or something...?)
Thank you for any help...
13 years 5 months ago #143763 by pamZGS
Replied by pamZGS on topic The Kunena 2.0 Menu
I am relatively new to this -- how do i go about providing you with a configuration report?
thanks,
Pam
13 years 5 months ago #143764 by Martin-123
I just found this (I hope it helps...?):
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : ca_cloudbase2_j25 | author: CloudAccess.net | version: 2.0.6 | creationdate: July 27, 2011
Plugins: None
13 years 5 months ago #143765 by pamZGS
I have Kunena 2.0.4
Joomla 2.5.11
if this is what you are asking for.
thanks,
Pam
13 years 5 months ago #143767 by pamZGS
Issue is resolved --it was a menu item alias issue as you suspected.
thanks for the direction.
Pam
Time to create page: 0.152 seconds
