Question How clean user cache
13 years 5 months ago #145106 by kurisutofue
Replied by kurisutofue on topic How clean user cache
From Jommla backend, Kunena Module -> User management:
I select a user that I want set as moderator.
In first layer, his rank was Administrator. I changed to Moderator.
In Moderation layer, he was setted as No. I changed to Yes and selected a forum category he should moderate.
After save, nothing change in the frontend. He still be Administrator.
However, From the backend, he's Moderator.
Do you have any idea about it? Maybe I forgot something?
The topic has been locked.
13 years 5 months ago #145308 by kurisutofue
Have you any suggestions?
13 years 5 months ago - 13 years 5 months ago #145310 by sozzled
Replied by sozzled on topic How clean user cache
(1) There is no "clean user cache" feature in K 2.0,
(2).Do you want to know how to assign a moderator in Kunena? Is that really what this topic is about?
I am not sure I understand your question. :unsure:
Last edit: 13 years 5 months ago by sozzled.
13 years 5 months ago #145316 by kurisutofue
I just want to know how to set a user as moderator, yes.
But the way I described below seems not to be the good one.
However, it seems there is nothing else?
13 years 5 months ago - 13 years 5 months ago #145325 by sozzled
kurisutofue wrote: I just want to know how to set a user as moderator, yes.
Here are a few topics that may help you:
I know that these topics relate to older versions of Kunena, but the principles are the same for K 3.0. To assign a moderator, you use the Kunena User Manager tools in the backend. There is no question about "cleaning the user cache".
13 years 4 months ago #145373 by kurisutofue
The problem has been finally solved. it was a problem with access group configuration.
Thank you for your help.
