Question How clean user cache
- kurisutofue
13 years 5 months ago - 13 years 5 months ago #145020
by kurisutofue
How clean user cache was created by kurisutofue
Hi guys,
How clean user cache from Kunena?
I still cannot find this option from "Synchronize users".
Is it anywhere else?
I need to update display in front of changes of user status (moderator or not) made from backend and I saw only user cache cleaning will give this effect.
Thanks!
Thanks!
Last edit: 13 years 5 months ago by sozzled. Reason: Remove reference to non-existent version of Kunena
The topic has been locked.
13 years 5 months ago #145026
by xillibit
Replied by xillibit on topic How clean user cache
Start by upgrading to Joomla! 2.5.11, then if you go in tools, you will find Synchronize users function
- kurisutofue
13 years 5 months ago #145037
by kurisutofue
Replied by kurisutofue on topic How clean user cache
Thank you for your reply.
Actually, before to upgrade, I already have "Synchronize users" function.
But I don't have "Clean user cache" option.
I just have the other ones.
So, if I upgrade Joomla from 2.5.7 to 2.5.11, this missing option will appear properly?
13 years 5 months ago #145040
by xillibit
Upgrading to Joomla! 2.5.11 is just be up to date
In synchronize users function in Kunena, there isn't a clean user cache function
- kurisutofue
13 years 5 months ago #145055
by kurisutofue
Maybe there is another way to solve fix my issue?
Currently, when I change user from administrator to moderator, it doesn't change in the frontend, however, it is sucessfuly recorded from the backend.
How to do for the front?
13 years 5 months ago #145080
by xillibit
Can-you describe exactly how do you proceed to set an user like a moderator ?
