Question How clean user cache
13 years 5 months ago - 13 years 5 months ago #145020 by kurisutofue
Hi guys,
How clean user cache from Kunena?
I still cannot find this option from "Synchronize users".
Is it anywhere else?
I need to update display in front of changes of user status (moderator or not) made from backend and I saw only user cache cleaning will give this effect.
Thanks!
Last edit: 13 years 5 months ago by sozzled. Reason: Remove reference to non-existent version of Kunena
The topic has been locked.
13 years 5 months ago #145026 by xillibit
Replied by xillibit on topic How clean user cache
Start by upgrading to Joomla! 2.5.11, then if you go in tools, you will find Synchronize users function
13 years 5 months ago #145037 by kurisutofue
Replied by kurisutofue on topic How clean user cache
Thank you for your reply.
Actually, before to upgrade, I already have "Synchronize users" function.
But I don't have "Clean user cache" option.
I just have the other ones.
So, if I upgrade Joomla from 2.5.7 to 2.5.11, this missing option will appear properly?
13 years 5 months ago #145040 by xillibit
Upgrading to Joomla! 2.5.11 is just be up to date
In synchronize users function in Kunena, there isn't a clean user cache function
13 years 5 months ago #145055 by kurisutofue
Maybe there is another way to solve fix my issue?
Currently, when I change user from administrator to moderator, it doesn't change in the frontend, however, it is sucessfuly recorded from the backend.
How to do for the front?
13 years 5 months ago #145080 by xillibit
Can-you describe exactly how do you proceed to set an user like a moderator ?
