Question K 1.7.2 -> K 2.0.4: all my topics are missing
I can't go to 3.0.X yet because of my PHP issue. I'm still trying to figure that out right now and at least I can try that on the one site (test25). That is already broken, so I can try to go from 2.0.X to 3.0.X.
sozzled wrote: Thanks. Not that I know anything about JEvents and XMAP (because I know nothing more than what I searched this forum and the internet):
The current versions are (according to what I have found):
JEvents 3.1.1
XMAP 2.3.3
I don't know the technical requirements for these things, however.
I need to keep xmap for SEO, but I can uninstall Jevents. That's one off the list to worry about. I can actually upgrade one now. Let me see.
I'm going to upgrade to K3.0.X then because I meet the requirements and again it is on the test site so it really won't matter. Actually, that's what it is there for. I just wish I had a 3rd.
1) I removed all the extensions that complain about php 5.4
2) Attempted to upgrade to K3.0.X with using Control Panel -> Global Configuration - Kunena
received this error:
JInstaller: :Install: Cannot find XML setup file
3) Downloaded the 3.0.X version from Kunena and installed it using -> extension manager
Same result. Looks good in the back (admin control panel) as all categories and other data seem to exist, but in the front end all the replies and topics are 0
interesting...
At least I'm on the most current version so we should have a bit easier time troubleshooting.
This is a known problem for people who try the "automatic upgrade" method - we know about it - and the case history is fully covered in the topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first? . The same thing will happen if you attempt to upgrade from K 1.7.2, too. I recommend you use the method described in the upgrade guide in the Wiki.tokenring wrote: Attempted to upgrade to K3.0.X with using Control Panel -> Global Configuration - Kunena
