Question K 1.7.2 -> K 2.0.4: all my topics are missing
13 years 2 months ago #146939 by tokenring
Thanks Jim. Why did you need to edit your post? ;-)
Can I send the text file of the output to someone rather than putting it in here?
I also have the DB back up. Please let me know another method of posting it. I don't want that in the forums for obvious reasons.
The topic has been locked.
13 years 2 months ago - 13 years 2 months ago #146940 by Jiminimonka
tokenring wrote: Can I send the text file of the output to someone rather than putting it in here?
The text file of the configuration report is useless/unreadable unless it is posted on a Kunena forum. The confidential parts of the Kunena configuration report are hidden from everyone except admin and moderators and the person who posts them.
tokenring wrote: I also have the DB back up. Please let me know another method of posting it. I don't want that in the forums for obvious reasons.
With prior agreement, items may be emailed privately to members of the team. The email addresses of team members are shown on the team page.
tokenring wrote: Thanks Jim. Why did you need to edit your post? ;-)
For the same reason that sozzled edits and changes most of his posts :lol: - editing for typos and such.
Please read the FAQ.
Only one question per topic.
Last edit: 13 years 2 months ago by sozzled. Reason: Removed xillibit's address from the post and correcting a couple of minor mistakes
13 years 2 months ago #146952 by tokenring
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : jf_texturia | author: Kreatif Multimedia GmbH | version: 1.0.0 | creationdate: 12/12/11
Third-party components: CommunityBuilder 1.9 | UddeIM 2.9
Plugins: None
13 years 2 months ago #146953 by tokenring
I wish I can upgrade to PHP 5.3. But if I do, then some of my other templates/modules and components I believe throw errors.
Let me see what I can figure out too on this end. I'll reach out to the vendors of my add-ons that have issues with 5.3 and I'll see what I can do.
13 years 2 months ago - 13 years 2 months ago #146958 by sozzled
Replying to msg #63: :woohoo: At last, we begin to see some light!
I suggest you make four important changes:
(1) Change your forum integration plugin settings as follows (recommendations shown in red):
Kunena - Community Builder Enabled: access=0 login=1 activity=1 avatar=1 profile=1 private=0
(2) Use the Blue Eagle template designed for K 2.0.4, not the one designed for K 1.7.2.
(3) Rebuild, completely, the Kunena menu items again using the technique described in the Wiki Kunena Menu issues ; you have conflicting menu items in your mainmenu menu.
(4) Restore your Kunena configuration settings back to the original "factory default" values.
Let's see if we can establish a bit of quality assurance with your site. ;)
The following user(s) said Thank You: tokenring
13 years 2 months ago #146961 by tokenring
okay this is great! I love this team work! :-)
while you guys were digging, this is what I see when I enable php 5.4
Strict Standards: Declaration of JParameter::loadSetupFile() should be compatible with JRegistry::loadSetupFile() in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/libraries/joomla/html/parameter.php on line 512
Strict Standards: Only variables should be assigned by reference in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/administrator/components/com_jevents/libraries/config.php on line 34
Strict Standards: Only variables should be assigned by reference in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/components/com_jevents/router.php on line 87
Strict Standards: Non-static method JEVHelper::getNow() should not be called statically in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/components/com_jevents/router.php on line 88
Strict Standards: Non-static method JVersion::isCompatible() should not be called statically in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/components/com_jevents/libraries/jevdate.php on line 9
Strict Standards: Only variables should be assigned by reference in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/components/com_jevents/libraries/helper.php on line 740
Strict Standards: Non-static method JSite::getMenu() should not be called statically in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/components/com_xmap/router.php on line 96
Strict Standards: Non-static method JApplication::getMenu() should not be called statically in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/includes/application.php on line 539
Strict Standards: Only variables should be assigned by reference in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/components/com_xmap/router.php on line 96
Strict Standards: Only variables should be assigned by reference in /homepages/6/d114815883/htdocs/funkyhousebeats_test25/components/com_xmap/router.php on line 102
Time to create page: 0.156 seconds
