Solved Allow only specified users to view/post (private part of forum)
13 years 7 months ago - 13 years 7 months ago #142765 by ernst67
Oops, I see you changed your post between the initial one and my reply.
This is my confoguration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : eris | author: RocketTheme, LLC | version: 3.2.19 | creationdate: April 2, 2012
Third-party components: UddeIM 2.9
Plugins: None
Modules: Kunena Latest 2.0.4
I will investigate your suspicion about changes made on the Kunena permissions, although I'm quite sure I haven't changed anything there...
Last edit: 13 years 7 months ago by ernst67.
13 years 7 months ago #142766 by ernst67
...as for the "viewing" permissions:
I can't find any setting for that in the Kunena component itself. Under the Options button I can only find a setting to enable/disable configuration and administration access per user group (see attached)
13 years 7 months ago #142771 by sozzled
Although these things are actually fairly easy (for someone who has the experience) it's not the easiest thing in the world to explain what do do on a discussion forum. Even face-to-face (e.g. via Skype) can take a while. If you have the time, you could write to me by email and we'll try to discuss the issues but it depends on your availability, your fluency with spoken English and the reliability of the telecommunications medium.
If you have Skype, write to me and we'll try to arrange a one-on-one time. :)
The following user(s) said Thank You: ernst67
13 years 7 months ago #142772 by ernst67
Oh.. well, I appreciate that very much!
Just sent you an email.... :-)
13 years 7 months ago #142774 by sozzled
Ernst's problem has been resolved. The test account that he had been using was setup as a global moderator.
I was glad to have been of service.
13 years 7 months ago #142775 by ernst67
OK, just for the sake of documentation: Here's how this matter was solved. Hopefully it's useful for those reading this topic later...
I did have that Skype session with Sozzled and we went through all the settings. Actually, everything was as described in previous posts in this topic.
Then I shared my screen and showed that although I was only a registered user, I could still see the forum category that was intended for developers only.
However...: Sozzled noticed that my Kunena user name had this "typical" colour: The colour of a Global Moderator. And yes.... Moderators can see all Kunena content.
Sometimes solutions are very close under your nose....
Thanks again Sozzled!
