Question Emoticons
17 years 9 months ago #4665 by bjornon
Replied by bjornon on topic Re:Emoticons
Hello -
I have a similar problem as described here; the (default) emoticons will not show in frontend or backend, I've verified that the file locations are correct - and I'm running both Joomla and Kunena in English. Permissions are 777 in all directories.
There are also one or two other icons missing or not showing.
Any luck? Any advice?
BjOlav
17 years 9 months ago #4672 by bjornon
FOUND IT!
Ok. My fault, but I did really check *most of* the settings. But when I checked the properties of the missing smilies at "Smilies management" - it said that my native language is "norwegian"...
So I copied the "english" folder and renamed the copy to "norwegian". And voila...
