Question Kunena 5.2.3 released
The modules and plugins are available in new version with a fix for that : github.com/Kunena/Kunena-Addons/releases/tag/5.2.1
I updated the latest Blue Eagle template which fixed one problem, Edit profile and Preferences are now available.Houndy post=216266
You can fix that by removing "post={$this->id}" from line 363 in libraries/kunena/forum/message/message.php
Users have noted that it is a bug in quoting now. The post number like post=216201 is included now.rich wrote:
Should not be a problem if you install K5.2.2 over it. But nevertheless create a backup before.Ozfooty Is it possible for me to change back to Kunena 5.2.2 until the bugs are ironed out in 5.2.3? This has caused a lot of problems.
Code:$message->message = "{$ wrote:
Code:" . $text . "Code:";
But several other problems exist. It has put line breaks in Categories and Last post and Moderators. private messages was not available, my Freelancer got it back but not sure how. Previously spell check was available automatically, now you have to activate it each time you post with 2 clicks and it is not available in Quick Reply, previously it was.
I have moderators for only 9 categories out of over 50 but after the last club, that moderator is now moderator for every category after it. When I removed him as moderator it made the moderator above him moderator for every category below. Falcon is only selected to be moderator for West Perth.
Where do-you see line breaks in categories ? Your screenshot is too small so i can't see it
Private messages isn't available yet in Kunena, so you need to use an another component to handle that
The spellchecker is done with your browser, but if you want to be handled by CKeditor your need to have your custom config file and remove this line : github.com/Kunena/Kunena-Forum/commit/a6...1e4fab3c504b5157679e
It amazes me that the "profile birthday entry" on this site has never been tried or checked if it is actually working!!
I get this error also with SW KBirthday for Kunena module, but only at birthdays, when this module is visible:Slacker wrote: Just upgraded to Kunena 5.2.3. After that white page with Error.
Maximal error reporting gave this message:
Error: Call to undefined method KunenaUser::getName(): Call to undefined method KunenaUser::getName()
I inactivated the Kunnena latest posts module and then the frontpage was visible without Error message.
extensions.joomla.org/extension/sw-kbirthday-for-kunena/
