Question Kunena 5.2.3 released
- Thank you received: 2543
Should not be a problem if you install K5.2.2 over it. But nevertheless create a backup before.Is it possible for me to change back to Kunena 5.2.2 until the bugs are ironed out in 5.2.3? This has caused a lot of problems.
- Complete Website Messed up (not only Forum)
Good that i made a backup to get back to 5.2.2
image missing https://itprisma.de/screen.png
Users have noted that it is a bug in quoting now. The post number like post=216201 is included now.rich wrote:
Should not be a problem if you install K5.2.2 over it. But nevertheless create a backup before.Ozfooty wrote: Is it possible for me to change back to Kunena 5.2.2 until the bugs are ironed out in 5.2.3? This has caused a lot of problems.
You can fix that by removing "post={$this->id}" from line 363 in libraries/kunena/forum/message/message.php
i use template : Crypsis
and i also have these problems.
I disabled the modules and now my forum works again, but i would like to have these modules.
what should i do ?
regards Jan
