Question Kunena & CB1.2 tabs / new field problem
17 years 6 months ago #9547 by nzrunner
I may have identified a very simple solution to this problem, or at least it worked for me.
  • In The CB Plugins section, Unpublish the Fireboard Forum Plugin
  • If it's installed, uninstall the Kunena Forum Plugin
  • Install the Kunena Forum Plugin
  • Rename the file /publichtml/.../components/com_comprofiler/plugin/user/plug_cbsimpleboard/cb.simpleboard.php
That worked for me and I could add new fields again.
16 years 10 months ago #33609 by Krycek
Hello nzrunner,
I tried this out but it doesn't completly work.
Explaination : I'd like to have forum activity with updated plugin in CB profiles AND have Kunena profiles linked to CB (not using K profiles).
Point is, with original forum integration plugin, forum activity is not as I'd like it to be (buttons not working, sliders not right ones).
-> I can fix it with the new forum activity plugin, unplishing and renaming old one.
However, once that's done, Kunena cannot link profiles to CB...
Seems that both wishes aren't compatible...
Any idea how to solve that ?
I googled this issue but this thread seems to be the most advanced one.
Installation :
CB 1.2.1
J! 1.5.14
Kunena 1.5.6
16 years 10 months ago #34282 by emeyer
I was an early adopter of Kunena and followed the directions to add the field options for threaded view and message ordering. Now I upgraded to the current version of Kunena, it's much better! But the old field in the CB profile for selecting thread or flat view is still there. The orering and signature works, but the thread/flat view selection doesn't.
I try unpublishing it, it still shows up in CB 'update preferences.'
I try deleting it from the CB fields, and CB says 'you can't delete a system field.'
Should I go in the database and delete the row? I'm reluctant to do anything in CB actually, as others observed it's very touchy, and I don't actually need it very much, the only thing that seems useful in it for me is the ability to list each user's posts on a separate page.
16 years 10 months ago #34491 by krileon
Old forum fields should be deleted manually from your database, but be sure to backup your database just encase. The new field for threaded, etc.. view is there primarily to continue to provide backwards compatibility support (fireboard).
16 years 9 months ago #34799 by emeyer
Thanks for th input. I'm still nervous about index mismatch after deleting a field, but I'll give it a try.
