Question Kunena & CB1.2 tabs / new field problem
17 years 2 months ago #6609 by philiplardner
I am running Joomla!1.5.9 under PHP5.1.6 with Kunena1.0.8 and Community Builder1.2.
When I try to add a new field in CB's Field Mamagement section I get the following error:
Fatal error: Cannot redeclare class getfireboardtab in /home/ihpa/www/newsite/components/com_comprofiler/plugin/user/plug_gjfireboard/fireboard.php on line 26
The guys on the CB forum suggest that this is a Kunena problem and not CB: www.joomlapolis.com/index.php?option=com...id=77&id=90077#90077
"You need to fix your plugin or inform the developer of the issue. It's conflicting with something else. You've declared the same class more then once; can't do that."
Can anyone shed any light on this?
Thanks,
Phil.
17 years 2 months ago #6640 by sozzled
Thanks for describing your problem, and the diagnosis/discussions you've previously undertaken, in such thoughtful detail. :cheer:
I've encountered a similar problem, too, but it's easily rectified. And, BTW, it is a Community Builder matter which they should have taken on board, because the solution is handled by CB's Plugin Manager!
As you may have already seen from the last post in your CB forum discussion, you've probably got the old Fireboard forum (cb.simpleboardtab) plugin still enabled (published) as well as the newer Kunena forum (cb.kunenatab) plugin. Unpublish the cb.simpleboard tab and see if that fixes the problem :)
17 years 2 months ago #6659 by philiplardner
Hi Sozzled - thanks for the pointers and clarification that it is a CB issue. I unpublished all the fireboard and kunena related tabs & plugins, and tried again to add a new field in CB Field Manager - still no joy - same error!
I'm a bit stumped. If I can't figure this one out by tomorrow night, I'll uninstall Junena and remove all other fireboard bits and see if that fixes the problem - then re-install kunena.
Phil.
17 years 1 month ago #8365 by KatiaB
Replied by KatiaB on topic Same problems
Hi Phil,
Did you manage to solve this? I'm having the same issue and followed you all through the forums of Joomlapolis and Kunena in the hope you've found the answer.
Guess you didn't.
@Sozzled: when I unpublish cb.simpleboardtab all the other tabs and fields related to forum in CB become unabled. Kunena still works on the site, but nothing shows up in the profiles anymore. Any thought?
Somebody?
Katia
17 years 1 month ago #8366 by philiplardner
Replied by philiplardner on topic Re:Same problems
Hi Katia,
Yes and no...! I *think* I traced the problem to the plug_groupjivetab (in CB Plugin Manager.) Here's what happened...
Iuninstalled Group Jive completely - deleted all references from all folders in my site and also all the tables in my database. This returned my site to some semblance of normality! I then re-installed GJ (but did not publish/activate any part of it) and made sure my site still worked. Then, one piece at a time, I published each of the plugins and modules, testing after each step. The error returned when I published the plug_groupjivetab.
Unpublishing the plugin did not seem to remove the problem, so I uninstalled everything again, gave it up as a bad job, and moved on to work on other parts of the site.
I downloaded some new updates to CB and installed them for another reason...
Returning to GroupJive a week or so later I started from scratch and downloaded a completely fresh copy of GJ and installed that. Lo and behold... it all worked! No errors! I don't know if there was an update to GJ or if the updates to CB I downloaded fixed the problem, but it is now working just fine! It still worries me that I didn't really track down the culprit, but I'm going to let sleeping dogs lie...
Sorry I can't be more help!
Phil.
For the record, I am using the following:
com_groupjive_v29a
gjplugin_integration_fireboard_v1.7e1
mod_gj_my_groups_v1.4a
plug_groupjivetab_v.1.6b
mod_cbcontent_1_2_RC
mod_cbpblatest_1_2_RC
I think those are all the relevant mods/plugs.
17 years 1 month ago #8378 by KatiaB
Replied by KatiaB on topic Re:Same problems
Thank you Phil for the quick reply!
Oh my, I'm gonna try what you did since the problem started after installing groupjive. Just have to figure out which, what and where to begin, :S .
Now I hope I can't mess up my database, I'm a total newbie to all this so if you have any warning at all before I delete tabels let me know please.
Keep your fingers crossed ;-)
Katia
