Question Kunena & CB1.2 tabs / new field problem
KatiaB wrote:
@Sozzled: when I unpublish cb.simpleboardtab all the other tabs and fields related to forum in CB become unabled. Kunena still works on the site, but nothing shows up in the profiles anymore. Any thought?
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
- philiplardner
- Junior Member
Yeaaaah, it's all working great now!!!! (doing a gratitude dance now:laugh: )
Thank you sooooo much for making my day Phil!
Hi Katia,
One other thing I forgot about until just now - I also got my ISP to upgrade my server from PHP4.x.x to PHP5.1.6. I don't know if this had anything to do with my solution, but it is possible!
Phil.
Don't know anything about servers and PHP but mine told me mine is supported by PHP5 already. So I guess it has nothing to do with my solution :lol:
Katia
Only thing i dont seem to get to work is for the forum to show within groupjive. Which files of Kunena do i need to edit to make it work?
I really appreciate your help!!!!
ili
Installation:
Joomla 1.5.9
Php 5x
com_groupjive_v29a
gjplugin_integration_fireboard_v1.7e1
plug_groupjivetab_v.1.6b
Just in case somebody else is looking for the same thing. Here is what i did. NO guarantee it will work for you too
1. back up files and DB
2. uninstall fireboard
3. install newest Kunena version
4. disable old GJ Fireboard plug in in CB -> plugins
5. install GJforum - the extended forum plugin available here www.groupjive.org/index.php?option=com_d...iew&gid=24&Itemid=59
6. enable plugin and enter correct category for kunena forum.
Hope this helps somebody some time!
ili :woohoo:
