Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
- propedeutique
First thanks for your module which works perfectly.
I have only one issue, related to css styling.
I would like to insert the "readon" class (standard class in joomla template.css) in the module but I don't know how to add this class in your code!
"readon" class should be used to display "Read more" text.
Thanks for your help.
Bye
If the Kunena latest module is on a page, the send message option in the pd_jsthumbs highslide option won't work and if you have the standard jomsocial pop up box enabled instead of the highslide popup, that doesn't work at all. Disable the kunena latest module and the both types of popups work correctly.
I did follow the link to the support site via extensions.joomla.org but it wasn't in English and I didn't know what to do there.
Anyone know how I can contact the writer of the module, It's brilliant but so is pd_jsthumbs and I desperately want to be able to use both.
thanks for any advice or direction offered.
mike
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
Looks like there are 2 different modules. Which one are you using? I ask because you posted this exact same thing in another thread prior to checking.
I thought there was only one, sorry. Have justr checked and it's mod_kunenalatest and the description text reads
<h3>Kunena latest module</h3> <p>Highly inspired by Rowan Seymour JBLatest, modified versions by fuQaHa, JoniJM, MetZ. Supports nearly all functionality of all these versions.</p> <p>Rewritten in nearly at all places; to support more features in new Joomla 1.5 and Kunena 1.0.6.</p> <p>Requirements: Kunena 1.0.6 (which requires MySQL 5.0!)</p> <p>Highlights:</p> <ul> <li>Joomla 1.5 design, templates, language file</li> <li>Joomla module class suffix and caching</li> <li>Supports 1 or 2 column layout; list or table style</li> <li>Supports multiple instances on page</li> <li>Item, tooltip, date/time format (with avatar, text message, number of replies support, thread hits)</li> <li>New post indicator support</li> <li>Links to profiles (Kunena, JomSocial, Community Builder, Clexus PM)</li> <li>Links to avatars (Kunena, JomSocial, Community Builder, Clexus PM)</li> <li>Include forums with specific access levels</li> <li>Include posts from specific categories, including the active category</li> <li>Show all, only first or only last posts from each thread</li> <li>Correct link to posts (changed in 1.0.5, so all older modules should be updated)</li> <li>SEF urls</li> <li>Languages: en, fr (by nktine, lavsteph), tr (by ugur), de (by Lintzy), cz (by Fenris)</li> </ul>
Does that help?
- grumblemarc
- Elite Member
So it wasn't this one extension. Our support forum is right now and also link from extensions.joomla.org is here.I did follow the link to the support site via extensions.joomla.org but it wasn't in English and I didn't know what to do there.
But this one helps me lot to understand some reported issues.
Be sure that you installed 1.0.x version, not the version 0.8 of JoniJnm!
Please with reporting issues be so kind and tell us versions of affected extensions.
Actually I am little-bit busy these days, but I am preparing new features and include suggested translations, tabular style which will be easy to edit and more.
I will try to do my best this weekend. But these days I have big issues with other projects, which are important for me and for community around my friends. So please, be patient.
At least I will try to solve easiest things this weekend.
