Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 7 months ago #6625 by jerry
Replied by jerry on topic Re:Kunena latest posts module
holgenoni wrote:
is it possible to make KunenaLatest module look like this:
Where to change some fontsize and the alignment of the avatar?
thx
holgenoni
You can create new template based on 4 templates in this module. If you submit your changes, we can add this as new template. Templates are files in folder tmpl.
17 years 7 months ago #6626 by jerry
Italywins wrote:
aniphreak wrote:
thanks for this...
many bugs tho that still the same with ported version of tarugis:
*not showing any avatar.
*readmore link not showing on 2 columns
hope it will be fixed soon!
Yep... confirm ... me too. :blink: :lol:
Actually these bugs are fixed. Which version did you install? %A in use?
17 years 7 months ago #6692 by holgenoni
I took a look on that files, and unfortunately i have no idea how to make the template look like this on my picture.:(
So the only thing that i can do is to wait, maybe someone make a template like this some day!:)
jerry wrote:
You can create new template based on 4 templates in this module. If you submit your changes, we can add this as new template. Templates are files in folder tmpl.[/quote]
17 years 7 months ago #6701 by holgenoni
I am proud to present you a new template named (newstyle) for KunenaLatest module!B)
It wasn't so difficult like I thought on the beginning.
But I'm not quite sure if the way i made it, is correct.
Because I had to make changes on the helper.php
The template look like this:
And here are the files that I've changed:
File Attachment:
File Name: newstyle.zip
File Size:5.68 KB
The only thing I don't know is how to change the font size of the answers.
Can someone tell me how to do that?
For use just replace the existing files with the attached one. And then go to the module configuration in joomla, and change the layout to "newstyle"!
@jerry
How to implement this in your original?
17 years 7 months ago #7249 by klausre
Hi, is it possible to ad a feature for crop avatar, so it has the same hight and widht?
17 years 6 months ago #7692 by itgl72
Is anyone using this with JACLPlus by www.byostech.com ?
