Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 7 months ago - 17 years 7 months ago #9112 by jerry
Replied by jerry on topic Re:Kunena latest posts module
version 1.0.35
- You don't need to uninstall. Install over previous version, it just works! Configuration preserverd! :)
- %O gives you online status
- read more gets template style
- serbian translation, thanx kmilos
- new style - "table tr" multicolumn (for holgenoni, set item format to
<td>%C<br />Antw.</td><td>%R %S<br /><small>%N %D</small></td><td>%A</td>
) This format defines table with rows; in item format you must specify table data tags.
Last edit: 17 years 7 months ago by jerry.
17 years 7 months ago #9114 by jerry
rincenwin wrote:
I want a suggestion over style. It's possible a style similar than the real forum? Thanks.
Be specific, how it should look like? In most situation this module is used outsite Kunena Forum component, where this module must match template style, not the Kunena Forum style.
17 years 7 months ago #9115 by jerry
holgenoni wrote:
is it possible to make KunenaLatest module look like this:
Where to change some fontsize and the alignment of the avatar?
thx
holgenoni
Yes look at annoucement 1.0.35 version, it should work for you
17 years 7 months ago #9116 by jerry
klausre wrote:
Hi, is it possible to ad a feature for crop avatar, so it has the same hight and widht?
So do you want to not respect aspect ratio of avatars? I think this is not nice. You can set the avatar height. If you find it usefull to not respect aspect ratio, call for this feature once more.
17 years 7 months ago #9117 by jerry
propedeutique wrote:
First thanks for your module which works perfectly.
I have only one issue, related to css styling.
I would like to insert the "readon" class (standard class in joomla template.css) in the module but I don't know how to add this class in your code!
"readon" class should be used to display "Read more" text.
Thanks for your help.
Bye
Thanks for your suggestion. You will find it in version 1.0.35.
17 years 7 months ago #9118 by jerry
Well for styling issues with other modules/components. Send me as much information as you have. I will try, to resolve issues on your site.
I think, that's all for now.
Time to create page: 0.146 seconds
