This category is for the module developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the module developed for K 1.6 and later versions.
Solved [Merged topic] Kunena Latest doesn't display posts to visitors
14 years 8 months ago #117520 by ccvortex
Greetings, thanks for a great free product.
My Latest Posts module will only show the latest posts if the user logs in even though I have guest post access enabled. How can I get the mod to show the latest posts to everyone whether they log in or not?
14 years 7 months ago #117529 by Jiminimonka
www.kunena.org/forum/179-Kunena-Latest-M...-is-logged-in#117223
Using the search feature will help, also posting in the right place.
Please read the FAQ.
Only one question per topic.
14 years 7 months ago #117540 by ccvortex
This forum is titled "K 1.6 and K 1.7 Support" how is this not the right place?
14 years 7 months ago #117574 by sozzled
*** Topic moved by moderator ***
G'day, ccvortex, and welcome to Kunena.
Thank you for your question (although I'm fairly sure that we've been asked about these things before). As Jiminimonka has written, sometimes it's easier to spend a few moments searching the forum for the answer.
I'm guessing that you are using K 1.7.2 with Kunena Latest 1.7.1. Is that right? It would help if I did not have to guess the other information that might help us, if you posted your configuration report. See the FAQs menu item above the forum page and read What information should I include when I ask for help (including how to post my configuration report)?
Thanks.
14 years 7 months ago #117637 by ccvortex
Hey sozzled, thanks for the reply.
Correct, I am using forum version 1.7.2 and module version 1.7.1. This is on Joomla 1.5.23 using the standard Joomla rhuk_milkyway template. Both the PHP and MySQL versions are the latest.
Is there any way to get the module to show the posts to everyone regardless of login status?
Thx again
14 years 7 months ago - 14 years 7 months ago #117638 by rich
This is a cache problem. You can to disable as workaround the cache for Kunena_Latest. Navigate into the folder "cache" and set the folder "mod_kunenalatest" on chmod 444. Then nothing can be written in, and also guest see the news promptly.
Last edit: 14 years 7 months ago by rich.
Time to create page: 0.237 seconds
