Question Kunena Discuss create hundreds of posts on my forum :/
Is the kunenadiscuss 1.7.1 the answer of our problem?
But let's rock...I'll let you know
yes it is, it's my bad start as a nubie. I'm searching joomla clone tool. Do you have any recommendation to clone the live site into a dev subdomain in same server? A link will be ok to follow. Thanks alot man.Matias wrote: You should always have test site -- upgrading complex site is always scary task.
There are a few tips on how you can make a backup of your site and use the backup to make a test site. See K 1.6 & K 1.7 Installation Guide
All of this can be done in one small shell script.
BUT unfortunately doing this needs some experience on how to use Unix/Linux (as do the most other tools), so you probably need to follow some instructions how to do it.
BTW, back to topic, after 2 days installing the discussion plugin, 6 hours ago I create a content using jreviews and this morning (now 9:29am here) I found it relapse again but so far it's only affect the latest content I create, so before getting worst I disabling it.
Any idea, why it's happen again?
Joomla 1.7.2 + JomSocial 2.4 + Kunena 1.7.1
