Kunena 6.4.13 Released
Question 1.5.12 -> 1.6.1 upgrade - post function only shows blank page
15 years 1 month ago #99912 by voidopolis.com
OK. I've tried a few different things at this point and I'm still stuck at the same position. Blank page on posts and replies.
upgrade from 1.5.12 -> v1.6.4_b4832_2011-05-07 - post = blank page
I upgrade to 1.5.12 -> 1.5.14 - tested successful - post function worked fine
upgrade 1.5.14 -> v1.6.4_b4832_2011-05-07 - post = blank page
I've gone through the troubleshooting procedures described in the "How_to_diagnose_blank_page_on_kunena" pages. I've enabled all debugging levels - nothing interesting shows up in any error logs!
I've uninstalled every old kunena & 3rd party Kunena module/plugin/component. I have the "mootools upgrade" enabled. I have tried the default template. I've turned off all caching. I've turned off and on all SEO stuff. I've turned off gzip compression.
so far nothing changes the fact that I get a blank page if I try to use the post/reply function.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : gk_party_freak | author: Robert Gavick - GavickPro | version: 1.0.1 | creationdate: 20/03/2010
Third-party components: Jomsocial 1.6.284
15 years 1 month ago #99979 by Matias
Do you see white page when you should see the form or when you try to post the message?
15 years 1 month ago #99982 by voidopolis.com
I get the blank page when posting or replying to a message. All other functions work fine. I can read messages, look through the forums, but any function that calls the post function is not working.
I can do a quick reply... but no reply, no edit, no new post, no quote...
dev.desmohio.com is my development build of my production site.
15 years 1 month ago #99988 by Matias
So the error happens when you should type your message (= reply topic form), but the actual posting (quick reply) works just fine..
It almost sounds like you have conflict between Kunena and template/plugin/module..
In Kunena 1.6.4 you should see a blue box if there's fatal error in Kunena. So the error happens outside of Kunena. Have you looked at your server logs?
15 years 1 month ago #99989 by voidopolis.com
Yes. I've turned on every bit of logging, and I nothing is giving me an error to investigate. I've tried the default Joomla template. I can switch off more modules. I'll turn them off one at a time and see if anything makes it work.
15 years 1 month ago #99994 by voidopolis.com
found it!
System - SEF
When its enabled, I get a blank screen - just on the post functions. when its disabled. everything works OK. Looks like I'll close this issue and start my investigation there.
