Question 1.5.12 -> 1.6.1 upgrade - post function only shows blank page
15 years 11 months ago #79094 by voidopolis.com
I'm currently on 1.5.12 on my production site. I duplicated my site (DEV copy) and upgraded to 1.6.1 (which was the latest stable until today it would seem). The upgrade looked like it worked, no errors on install, forum showed up normally. The issue I have is when you do any "post" function, it just tosses up a completely blank page. new post, reply, quick reply, edit - all post functions display the same completely blank page.
I tried completely removing my forum com,mods,plugins; deleted the DB tables and deleted all kunena directories from the site but left everything else the same and did a fresh 1.6.1 install. that worked fine. all post functions working just fine.
I restored the site completely again and did the upgrade again. Same problem exists. I tried turning all debugging, no errors showing up anywhere.
any ideas?
The following user(s) said Thank You: scept1c
15 years 11 months ago #79105 by 810
Hi, can you add the kunena report here.
regards 810
15 years 11 months ago #79121 by xillibit
Enable debug mode in kunena and Joomla! configuration panel , if you don't see anything which can help.
Look in apache and php error log.
15 years 9 months ago - 15 years 9 months ago #85709 by voidopolis.com
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : gk_party_freak | author: Robert Gavick - GavickPro | version: 1.0.1 | creationdate: 20/03/2010
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.0.5) | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 2.0 beta) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.0.47) | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
Last edit: 15 years 9 months ago by voidopolis.com.
15 years 9 months ago #85713 by voidopolis.com
I finally got back to troubleshooting my installation issues. I'm still having the same issue. After a successful upgrade to the latest version, any function using "post" will only display a blank page.
15 years 6 months ago #94965 by mlotziii
I am having the same problem as well. Click on reply and a page comes up but no area to post a reply. It is kinda weird. All was working great until I moved servers.
