Question Change legend colours: Site Administrator, Global Moderator, etc.
14 years 3 months ago - 14 years 3 months ago #119706 by danss2
Thank you, sozzled, for reposting the answer, as the link in the answer post is indeed dead.
PS - didn't help :-(
Last edit: 14 years 3 months ago by danss2.
14 years 3 months ago #119710 by danss2
I did find this code in kunena.forum.css but without any colors indicated.... It looks like this:
#Kunena .kwho-admin { } #Kunena .kwho-globalmoderator { } #Kunena .kwho-moderator { } #Kunena .kwho-user { } #Kunena .kwho-guest { } #Kunena .kwho-banned { } #Kunena .kwho-blocked { }
I've tried to insert a color code into that (ie color: #CD3F01 !important;) but nothing changed either...
14 years 3 months ago #119711 by Jiminimonka
sozzled wrote: To change the legend colours, add the following lines at the end of your Joomla site template CSS file:
You mis-read Sozzled's post.
Please read the FAQ.
Only one question per topic.
14 years 3 months ago - 14 years 3 months ago #119713 by danss2
I didn't. I replied to it in my previous post, saying that it did not help ;-)
14 years 3 months ago #119715 by Jiminimonka
As I said, you mis-read Sozzled's post, you should not edit the Kunena CSS file, you should be editing the Joomla CSS file.
14 years 3 months ago - 14 years 3 months ago #119716 by sozzled
I looked at the website www.chat.com.ph/forum and there is nothing basically wrong with this website (except that it's using K 1.7.1 and we recommend that upgrading it to K 1.7.2).
I only have one question here for danss2: which file did you change? In this case you should add your changes to the end of the file ../templates/ja_social/css/template.css. The answer will be different in everyone else's case. It all depends on which file is the main Joomla site template CSS file. Only you know which file is your main Joomla site template CSS file.
There is a reason why, if you try to modify the file kunena.forum.css things won't work (see Minified CSS ) just as there are many good reasons why you should not modify any original Kunena source files. Please upgrade to K 1.7.2 and then add the changes that you need to the end of your Joomla site template CSS file.
Last edit: 14 years 3 months ago by sozzled.
