Important SOLVED! quote button problem...
I am not programmer, even though i am the webmaster of this site:
www.cil-online.com/forum/ask/howtohanjinliang.html
as you can see that the quote button is in disorder, some people told me that is a CSS problem, but after reading this post, i am still lost here.
Can you kindly take a look at it, and give me a hint of how to fix it? My issue is not RT one, since my template is not RT.
Can anyone tell me how to edit CSS files please.
You also need to know how to use FTP (or some other such tool) to copy the CSS files from your webserver to your PC, edit the file on the PC, and then copy the file back to the webserver. Is that what you wanted to know when you asked the question "How to edit CSS files?"
However, I think we're rather drifting away from the issues raised at the beginning of this topic. If we start getting bogged down in basic matters like "how to edit CSS files" then I think those issues should be taken away from this topic, wouldn't you agree?
sozzled wrote: I use Notepad to edit CSS files.
Maybe you not understand me bro.:laugh:
Imean which line on CSS file I should modify, I know the CSS files edited using Notepad++
I just need to know which CSS file and wich line I must modify
Thank you.
For some reason, my quote button is screwed up - see attached image.
How can I fix this? Is this due to a problem with my template?
Many thanks indeed.
