Important SOLVED! quote button problem...
Because of that I suggest that we use temporal solution and fix this issue for the next major release.
- snilloconator
- Premium Member
- aka snilly
Cerberus wrote: No to be honest it has nothing to do with kunena, its the new joomla 1.5.20 mootools 1.2 plugin that causes the issue because it is incompatable with teh old mootools 1.1 plugin and sadly RT still use the old plugin when they make there templates. Kunena is just ahead of the game in making there software fully mootools 1.2 and J1.6 complient
hi again cerberus,
i do respect all the time and effort you put into helping out kunena users, but unfortunately i keep seeing statements from you about rockettheme products and compatibility issues which are simply untrue.
if you don't mind, i would like to correct this once and for all and would appreciate it very much if you stopped spreading false information like that.
at this point all rockettheme club templates released after august 2008 have been updated for mootools 1.2.4 compatibility and will work fine with the mootools upgrade plugin enabled (and also disabled).
the previous templates are currently being worked on and tested and will be released over the next couple of weeks.
regarding the extensions, the following extensions have been updated and are compatible with mootools 1.2.4:
RokStories
RokBox
RokNavMenu
RokNewsPager
RokAjaxSearch
RokTabs
RokPad
RokCandy
RokTwittie
RokQuickCart
RokNewsFlash
RokWeather
RokStock
RokSlideShow
Rokvirtuemart_categories (template only release)
Rokvirtuemart_scroller (template only release)
RokMiniNews (template only release)
RokFeature (template only release)
kat
rockettheme
Thank you soo much for all the information! I completely agree with you and want to re-iterate that I believe RT is really the leader in this area. We are using RT themes on various sites and even here on Kunena.com we are running a modified free GPL theme from RT.
Thank You!
Oliver
