Question 500 Error in Forum Configuration and forum
14 years 10 months ago #98909 by Bob Britt
Thanks C0n, I have tried both arrangements with no difference.
14 years 10 months ago #98939 by Matias
.htaccess looks good..
The odd thing is that Kunena (1.6.4) should catch all PHP errors and show a nice box saying what goes wrong and where the issue was found. So it's very likely that this error comes from somewhere else.
Have you already found your error.log file?
14 years 10 months ago #99029 by Bob Britt
Yes, found the error log, only thing I find being recorded is this.
[21-Jun-2011 15:12:22] PHP Notice: Undefined index: name in /home/XXXXXX/public_html/templates/tntsmalllogo/html/mod_mainmenu/default.php on line 129
Which consist of this.
if (($node->name() == 'li') && ($id = $node->attributes('id'))) { if ($node->attributes('class')) { $node->addAttribute('class', $node->attributes('class').' item'.$id); } else { $node->addAttribute('class', 'item'.$id); } }
The last bracket being line 129.
I don't think this is related because the times this error is recorded is not the times I attempted to get to the Kunena Forum Config page.
14 years 10 months ago #99418 by Bob Britt
I have dug and dug and can not find an error message being generated or recorded anywhere in the logs. Even had the host after it but still nothing. I know we can't resolve this without a specific error message. Thanks for everyone's help, hope I can get some resolution on this.
14 years 10 months ago #99580 by Matias
Yes, notification isn't related to 500 Error..
I really don't know how to help you without seeing what is going wrong. One thing that causes configuration page not to load is to have some illegal or unexpected data in configuration. I bet it is in integration, so..
If you have access to database (phpmyadmin), go to jos_kunena_configuration and edit it. Change following values:
integration_avatar = kunena
integration_profile = kunena
integration_login = joomla
integration_private = none
integration_activity = none
integration_access = joomla
14 years 10 months ago #99642 by Bob Britt
Well that sure will show us if it's the integration. I'll let you know the results.
Time to create page: 0.230 seconds
