- Thank you received: 2
Question 500 Error in Forum Configuration and forum
In the mean time the fix is to add check if users variable is array before calling the function.
Matias wrote: array_combine() bug has been fixed in K1.6.5 -- it was caused by CB removing all subscribers from the list (which was unexpected as i thought that array_combine would accept empty arrays).
Didn't know y'all called this a bug???
You're going to save me a massive amount of work if this is the fix. Now...how exactly can I apply the fix you're talking about?
Go to the end of the file and find the function below. Replace the whole function with this new version (only few lines changed, but it's easier to replace the whole thing):
Do you see anything new?
What are the current issues exactly?
