- Thank you received: 3
Question Double Login Issue
- freedomcoach
- Premium Member
16 years 2 weeks ago #69471
by freedomcoach
Replied by freedomcoach on topic Re: Aw: Double Login Issue
So far both the CB Login module and the Kunena login module are working with K1.6.1 without double login issue. For now, I'm going to stay with CB login to see how it goes and I'll switch to Kunena login if needed.
Sincerely,
Howard
Sincerely,
Howard
The topic has been locked.
16 years 2 weeks ago #69473
Replied by sozzled on topic Re: Double Login Issue
I'm very pleased to hear that your "double login" issues have been resolved, Howard.
- freedomcoach
- Premium Member
16 years 2 weeks ago #69476
by freedomcoach
Replied by freedomcoach on topic Re: Double Login Issue
Sorry, I spoke too soon again. The double login issue is persisting and exists with both the CB login module AND the Kunena Login Module. The most irritating aspect is that it is intermittent.
When I haven't logged in for a while, say a few hours, the second login occurs. If I then logout and login again immediately, it does not show up and I'm taken directly to the forum. This leads me to believe that something is timing out causing the second login request. Very perplexing.
Sincerely,
Howard
Sincerely,
Howard
16 years 2 weeks ago - 16 years 2 weeks ago #69479
Can you check something for me, Howard:
(1) What is your Joomla session lifetime?
(2) Your Kunena session lifetime is 3600 seconds (= 60 minutes)
This was given as a hint in msg #8 earlier in this topic.
Last edit: 16 years 2 weeks ago by sozzled.
- freedomcoach
- Premium Member
16 years 2 weeks ago #69483
by freedomcoach
It was sent to 30 minutes but I increased it to 60 minutes.
Another point that is noteworthy is that if I set my forum to registered users only, it will not allow me as a logged in member to enter the forum. It posts a message that only community members are allowed in even though I'm already logged in.
Somehow, Kunena is NOT receiving the information from Joomla or CB, that I am a registered user logged in. This is my hunch. It seems to be a miscommunication between components.
Howard
Howard
16 years 2 weeks ago #69494
by fxstein
Replied by fxstein on topic Re: Double Login Issue
Still not sure what could cause this.
There is no such 'communication' between Joomla, CB and Kunena.
Kunena simply gets the Joomla user object passed into its code. We do not control nor perform any login operations. It is Joomla itself that seems to loose the logged in session.
Definitely something we need to figure out.
