Question Cannot post to forum, not sure why?
14 years 8 months ago #105590 by gwmbox
Ok I have optimised the tables no luck, I also went into debug (Joomla) and its gives me heaps of info I am not sure what I am looking for. Plus I did not want to attach as I am sure it has info there I do not want public - can I send it to you another way?
Basically what is happening is that I can write up the post in the new post form and then I select the SUBMIT button, then all I see is the top headr part of the kunena page like this
The Schema info is here
Schema Difference
<?xml version="1.0" encoding="utf-8"?> <!DOCTYPE schema> <schema type="diff"> <table name="kunena_config" action="alter"> <field name="captcha_post_limit" action="unknown"/> <field name="recaptcha_publickey" action="unknown"/> <field name="recaptcha_privatekey" action="unknown"/> <field name="recaptcha_theme" action="unknown"/> </table> <table name="kunena_polls_users" action="alter"> <field name="lasttime" type="timestamp" null="0" extra="on update CURRENT_TIMESTAMP" action="alter" after="votes"/> </table> <table name="kunenadiscuss" action="unknown"/> </schema>
Database Schema
<?xml version="1.0" encoding="utf-8"?> <!DOCTYPE schema> <schema> <table name="kunena_announcement"> <field primary_key="yes" name="id" type="int(3)" null="0" extra="auto_increment"/> <field name="title" type="tinytext" null="0"/> <field name="sdescription" type="text" null="0"/> <field name="description" type="text" null="0"/> <field name="created" type="datetime" null="0" default="0000-00-00 00:00:00"/> <field name="published" type="tinyint(1)" null="0" default="0"/> <field name="ordering" type="tinyint(4)" null="0" default="0"/> <field name="showdate" type="tinyint(1)" null="0" default="1"/> <key name="PRIMARY" unique="1" columns="id"/> </table> <table name="kunena_attachments"> <field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/> <field name="mesid" type="int(11)" null="0" default="0"/> <field name="userid" type="int(11)" null="0" default="0"/> <field name="hash" type="char(32)" null="1"/> <field name="size" type="int(11)" null="1"/> <field name="folder" type="varchar(255)" null="0"/> <field name="filetype" type="varchar(20)" null="0"/> <field name="filename" type="varchar(255)" null="0"/> <key name="PRIMARY" unique="1" columns="id"/> <key name="mesid" columns="mesid"/> <key name="userid" columns="userid"/> <key name="hash" columns="hash"/> <key name="filename" columns="filename"/> </table> <table name="kunena_categories"> <field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/> <field name="parent" type="int(11)" null="1" default="0"/> <field name="name" type="tinytext" null="1"/> <field name="cat_emoticon" type="tinyint(4)" null="0" default="0"/> <field name="locked" type="tinyint(4)" null="0" default="0"/> <field name="alert_admin" type="tinyint(4)" null="0" default="0"/> <field name="moderated" type="tinyint(4)" null="0" default="1"/> <field name="moderators" type="varchar(15)" null="1"/> <field name="accesstype" type="varchar(20)" null="0" default="none"/> <field name="access" type="int(11)" null="0" default="0"/> <field name="pub_access" type="tinyint(4)" null="1" default="1"/> <field name="pub_recurse" type="tinyint(4)" null="1" default="1"/> <field name="admin_access" type="tinyint(4)" null="1" default="0"/> <field name="admin_recurse" type="tinyint(4)" null="1" default="1"/> <field name="ordering" type="smallint(6)" null="0" default="0"/> <field name="future2" type="int(11)" null="1" default="0"/> <field name="published" type="tinyint(4)" null="0" default="0"/> <field name="checked_out" type="tinyint(4)" null="0" default="0"/> <field name="checked_out_time" type="datetime" null="0" default="0000-00-00 00:00:00"/> <field name="review" type="tinyint(4)" null="0" default="0"/> <field name="allow_anonymous" type="tinyint(4)" null="0" default="0"/> <field name="post_anonymous" type="tinyint(4)" null="0" default="0"/> <field name="hits" type="int(11)" null="0" default="0"/> <field name="description" type="text" null="0"/> <field name="headerdesc" type="text" null="0"/> <field name="class_sfx" type="varchar(20)" null="0"/> <field name="allow_polls" type="tinyint(4)" null="0" default="0"/> <field name="id_last_msg" type="int(10)" null="0" default="0"/> <field name="numTopics" type="mediumint(8)" null="0" default="0"/> <field name="numPosts" type="mediumint(8)" null="0" default="0"/> <field name="time_last_msg" type="int(11)" null="1"/> <key name="PRIMARY" unique="1" columns="id"/> <key name="parent" columns="parent"/> <key name="published_pubaccess_id" columns="published,pub_access,id"/> <key name="msg_id" columns="id_last_msg"/> <key name="category_access" columns="accesstype,access"/> </table> <table name="kunena_config"> <field primary_key="yes" name="id" type="int(11)" null="0" default="0"/> <field name="board_title" type="text" null="1"/> <field name="email" type="text" null="1"/> <field name="board_offline" type="int(11)" null="1"/> <field name="board_ofset" type="text" null="1"/> <field name="offline_message" type="text" null="1"/> <field name="enablerss" type="int(11)" null="1"/> <field name="enablepdf" type="int(11)" null="1"/> <field name="threads_per_page" type="int(11)" null="1"/> <field name="messages_per_page" type="int(11)" null="1"/> <field name="messages_per_page_search" type="int(11)" null="1"/> <field name="showhistory" type="int(11)" null="1"/> <field name="historylimit" type="int(11)" null="1"/> <field name="shownew" type="int(11)" null="1"/> <field name="jmambot" type="int(11)" null="1"/> <field name="disemoticons" type="int(11)" null="1"/> <field name="template" type="text" null="1"/> <field name="showannouncement" type="int(11)" null="1"/> <field name="avataroncat" type="int(11)" null="1"/> <field name="catimagepath" type="text" null="1"/> <field name="showchildcaticon" type="int(11)" null="1"/> <field name="annmodid" type="text" null="1"/> <field name="rtewidth" type="int(11)" null="1"/> <field name="rteheight" type="int(11)" null="1"/> <field name="enableforumjump" type="int(11)" null="1"/> <field name="reportmsg" type="int(11)" null="1"/> <field name="username" type="int(11)" null="1"/> <field name="askemail" type="int(11)" null="1"/> <field name="showemail" type="int(11)" null="1"/> <field name="showuserstats" type="int(11)" null="1"/> <field name="showkarma" type="int(11)" null="1"/> <field name="useredit" type="int(11)" null="1"/> <field name="useredittime" type="int(11)" null="1"/> <field name="useredittimegrace" type="int(11)" null="1"/> <field name="editmarkup" type="int(11)" null="1"/> <field name="allowsubscriptions" type="int(11)" null="1"/> <field name="subscriptionschecked" type="int(11)" null="1"/> <field name="allowfavorites" type="int(11)" null="1"/> <field name="maxsubject" type="int(11)" null="1"/> <field name="maxsig" type="int(11)" null="1"/> <field name="regonly" type="int(11)" null="1"/> <field name="changename" type="int(11)" null="1"/> <field name="pubwrite" type="int(11)" null="1"/> <field name="floodprotection" type="int(11)" null="1"/> <field name="mailmod" type="int(11)" null="1"/> <field name="mailadmin" type="int(11)" null="1"/> <field name="captcha" type="int(11)" null="1"/> <field name="mailfull" type="int(11)" null="1"/> <field name="allowavatar" type="int(11)" null="1"/> <field name="allowavatarupload" type="int(11)" null="1"/> <field name="allowavatargallery" type="int(11)" null="1"/> <field name="avatarquality" type="int(11)" null="1"/> <field name="avatarsize" type="int(11)" null="1"/> <field name="allowimageupload" type="int(11)" null="1"/> <field name="allowimageregupload" type="int(11)" null="1"/> <field name="imageheight" type="int(11)" null="1"/> <field name="imagewidth" type="int(11)" null="1"/> <field name="imagesize" type="int(11)" null="1"/> <field name="allowfileupload" type="int(11)" null="1"/> <field name="allowfileregupload" type="int(11)" null="1"/> <field name="filetypes" type="text" null="1"/> <field name="filesize" type="int(11)" null="1"/> <field name="showranking" type="int(11)" null="1"/> <field name="rankimages" type="int(11)" null="1"/> <field name="avatar_src" type="text" null="1"/> <field name="fb_profile" type="text" null="1"/> <field name="pm_component" type="text" null="1"/> <field name="userlist_rows" type="int(11)" null="1"/> <field name="userlist_online" type="int(11)" null="1"/> <field name="userlist_avatar" type="int(11)" null="1"/> <field name="userlist_name" type="int(11)" null="1"/> <field name="userlist_username" type="int(11)" null="1"/> <field name="userlist_posts" type="int(11)" null="1"/> <field name="userlist_karma" type="int(11)" null="1"/> <field name="userlist_email" type="int(11)" null="1"/> <field name="userlist_usertype" type="int(11)" null="1"/> <field name="userlist_joindate" type="int(11)" null="1"/> <field name="userlist_lastvisitdate" type="int(11)" null="1"/> <field name="userlist_userhits" type="int(11)" null="1"/> <field name="latestcategory" type="text" null="1"/> <field name="showstats" type="int(11)" null="1"/> <field name="showwhoisonline" type="int(11)" null="1"/> <field name="showgenstats" type="int(11)" null="1"/> <field name="showpopuserstats" type="int(11)" null="1"/> <field name="popusercount" type="int(11)" null="1"/> <field name="showpopsubjectstats" type="int(11)" null="1"/> <field name="popsubjectcount" type="int(11)" null="1"/> <field name="usernamechange" type="int(11)" null="1"/> <field name="rules_infb" type="int(11)" null="1"/> <field name="rules_cid" type="int(11)" null="1"/> <field name="help_infb" type="int(11)" null="1"/> <field name="help_cid" type="int(11)" null="1"/> <field name="showspoilertag" type="int(11)" null="1"/> <field name="showvideotag" type="int(11)" null="1"/> <field name="showebaytag" type="int(11)" null="1"/> <field name="trimlongurls" type="int(11)" null="1"/> <field name="trimlongurlsfront" type="int(11)" null="1"/> <field name="trimlongurlsback" type="int(11)" null="1"/> <field name="autoembedyoutube" type="int(11)" null="1"/> <field name="autoembedebay" type="int(11)" null="1"/> <field name="ebaylanguagecode" type="text" null="1"/> <field name="fbsessiontimeout" type="int(11)" null="1"/> <field name="highlightcode" type="int(11)" null="1"/> <field name="rss_type" type="text" null="1"/> <field name="rss_timelimit" type="text" null="1"/> <field name="rss_limit" type="int(11)" null="1"/> <field name="rss_included_categories" type="text" null="1"/> <field name="rss_excluded_categories" type="text" null="1"/> <field name="rss_specification" type="text" null="1"/> <field name="rss_allow_html" type="int(11)" null="1"/> <field name="rss_author_format" type="text" null="1"/> <field name="rss_author_in_title" type="int(11)" null="1"/> <field name="rss_word_count" type="text" null="1"/> <field name="rss_old_titles" type="int(11)" null="1"/> <field name="rss_cache" type="int(11)" null="1"/> <field name="fbdefaultpage" type="text" null="1"/> <field name="default_sort" type="text" null="1"/> <field name="alphauserpointsnumchars" type="int(11)" null="1"/> <field name="sef" type="int(11)" null="1"/> <field name="sefcats" type="int(11)" null="1"/> <field name="sefutf8" type="int(11)" null="1"/> <field name="showimgforguest" type="int(11)" null="1"/> <field name="showfileforguest" type="int(11)" null="1"/> <field name="pollnboptions" type="int(11)" null="1"/> <field name="pollallowvoteone" type="int(11)" null="1"/> <field name="pollenabled" type="int(11)" null="1"/> <field name="poppollscount" type="int(11)" null="1"/> <field name="showpoppollstats" type="int(11)" null="1"/> <field name="polltimebtvotes" type="text" null="1"/> <field name="pollnbvotesbyuser" type="int(11)" null="1"/> <field name="pollresultsuserslist" type="int(11)" null="1"/> <field name="maxpersotext" type="int(11)" null="1"/> <field name="ordering_system" type="text" null="1"/> <field name="post_dateformat" type="text" null="1"/> <field name="post_dateformat_hover" type="text" null="1"/> <field name="hide_ip" type="int(11)" null="1"/> <field name="js_actstr_integration" type="int(11)" null="1"/> <field name="imagetypes" type="text" null="1"/> <field name="checkmimetypes" type="int(11)" null="1"/> <field name="imagemimetypes" type="text" null="1"/> <field name="imagequality" type="int(11)" null="1"/> <field name="thumbheight" type="int(11)" null="1"/> <field name="thumbwidth" type="int(11)" null="1"/> <field name="hideuserprofileinfo" type="text" null="1"/> <field name="integration_access" type="text" null="1"/> <field name="integration_login" type="text" null="1"/> <field name="integration_avatar" type="text" null="1"/> <field name="integration_profile" type="text" null="1"/> <field name="integration_private" type="text" null="1"/> <field name="integration_activity" type="text" null="1"/> <field name="boxghostmessage" type="int(11)" null="1"/> <field name="userdeletetmessage" type="int(11)" null="1"/> <field name="latestcategory_in" type="int(11)" null="1"/> <field name="topicicons" type="int(11)" null="1"/> <field name="onlineusers" type="int(11)" null="1"/> <field name="debug" type="int(11)" null="1"/> <field name="catsautosubscribed" type="int(11)" null="1"/> <field name="showbannedreason" type="int(11)" null="1"/> <field name="version_check" type="int(11)" null="1"/> <field name="showthankyou" type="int(11)" null="1"/> <field name="showpopthankyoustats" type="int(11)" null="1"/> <field name="popthankscount" type="int(11)" null="1"/> <field name="mod_see_deleted" type="int(11)" null="1"/> <field name="bbcode_img_secure" type="text" null="1"/> <field name="listcat_show_moderators" type="int(11)" null="1"/> <field name="lightbox" type="int(11)" null="1"/> <field name="activity_limit" type="int(11)" null="1"/> <field name="show_list_time" type="int(11)" null="1"/> <field name="show_session_type" type="int(11)" null="1"/> <field name="show_session_starttime" type="int(11)" null="1"/> <field name="userlist_allowed" type="int(11)" null="1"/> <field name="userlist_count_users" type="int(11)" null="1"/> <field name="enable_threaded_layouts" type="int(11)" null="1"/> <field name="category_subscriptions" type="text" null="1"/> <field name="topic_subscriptions" type="text" null="1"/> <field name="pubprofile" type="int(11)" null="1"/> <field name="thankyou_max" type="int(11)" null="1"/> <field name="email_recipient_count" type="int(11)" null="1"/> <field name="email_recipient_privacy" type="text" null="1"/> <field name="email_visible_address" type="text" null="1"/> <field name="captcha_post_limit" type="int(11)" null="1"/> <field name="recaptcha_publickey" type="text" null="1"/> <field name="recaptcha_privatekey" type="text" null="1"/> <field name="recaptcha_theme" type="text" null="1"/> <key name="PRIMARY" unique="1" columns="id"/> </table> <table name="kunena_favorites"> <field primary_key="yes" name="thread" type="int(11)" null="0" default="0"/> <field primary_key="yes" name="userid" type="int(11)" null="0" default="0"/> <key name="thread" unique="1" columns="thread,userid"/> <key name="userid" columns="userid"/> </table> <table name="kunena_groups"> <field primary_key="yes" name="id" type="int(4)" null="0" extra="auto_increment"/> <field name="title" type="varchar(255)" null="1"/> <key name="PRIMARY" unique="1" columns="id"/> </table> <table name="kunena_messages"> <field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/> <field name="parent" type="int(11)" null="1" default="0"/> <field name="thread" type="int(11)" null="1" default="0"/> <field name="catid" type="int(11)" null="0" default="0"/> <field name="name" type="tinytext" null="1"/> <field name="userid" type="int(11)" null="0" default="0"/> <field name="email" type="tinytext" null="1"/> <field name="subject" type="tinytext" null="1"/> <field name="time" type="int(11)" null="0" default="0"/> <field name="ip" type="varchar(15)" null="1"/> <field name="topic_emoticon" type="int(11)" null="0" default="0"/> <field name="locked" type="tinyint(4)" null="0" default="0"/> <field name="hold" type="tinyint(4)" null="0" default="0"/> <field name="ordering" type="int(11)" null="1" default="0"/> <field name="hits" type="int(11)" null="1" default="0"/> <field name="moved" type="tinyint(4)" null="1" default="0"/> <field name="modified_by" type="int(7)" null="1"/> <field name="modified_time" type="int(11)" null="1"/> <field name="modified_reason" type="tinytext" null="1"/> <key name="PRIMARY" unique="1" columns="id"/> <key name="thread" columns="thread"/> <key name="ip" columns="ip"/> <key name="userid" columns="userid"/> <key name="time" columns="time"/> <key name="locked" columns="locked"/> <key name="hold_time" columns="hold,time"/> <key name="parent_hits" columns="parent,hits"/> <key name="catid_parent" columns="catid,parent"/> </table> <table name="kunena_messages_text"> <field primary_key="yes" name="mesid" type="int(11)" null="0" default="0"/> <field name="message" type="text" null="0"/> <key name="PRIMARY" unique="1" columns="mesid"/> </table> <table name="kunena_moderation"> <field primary_key="yes" name="catid" type="int(11)" null="0" default="0"/> <field primary_key="yes" name="userid" type="int(11)" null="0" default="0"/> <field name="future1" type="tinyint(4)" null="1" default="0"/> <field name="future2" type="int(11)" null="1" default="0"/> <key name="PRIMARY" unique="1" columns="catid,userid"/> </table> <table name="kunena_polls"> <field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/> <field name="title" type="varchar(100)" null="0"/> <field name="threadid" type="int(11)" null="0"/> <field name="polltimetolive" type="datetime" null="1"/> <key name="PRIMARY" unique="1" columns="id"/> <key name="threadid" columns="threadid"/> </table> <table name="kunena_polls_options"> <field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/> <field name="pollid" type="int(11)" null="1"/> <field name="text" type="varchar(100)" null="1"/> <field name="votes" type="int(11)" null="1"/> <key name="PRIMARY" unique="1" columns="id"/> <key name="pollid" columns="pollid"/> </table> <table name="kunena_polls_users"> <field name="pollid" type="int(11)" null="1"/> <field name="userid" type="int(11)" null="1"/> <field name="votes" type="int(11)" null="1"/> <field name="lasttime" type="timestamp" null="0" default="0000-00-00 00:00:00"/> <field name="lastvote" type="int(11)" null="1"/> <key name="pollid" unique="1" columns="pollid,userid"/> </table> <table name="kunena_ranks"> <field primary_key="yes" name="rank_id" type="mediumint(8) unsigned" null="0" extra="auto_increment"/> <field name="rank_title" type="varchar(255)" null="0" default=""/> <field name="rank_min" type="mediumint(8) unsigned" null="0" default="0"/> <field name="rank_special" type="tinyint(1) unsigned" null="0" default="0"/> <field name="rank_image" type="varchar(255)" null="0" default=""/> <key name="PRIMARY" unique="1" columns="rank_id"/> </table> <table name="kunena_sessions"> <field primary_key="yes" name="userid" type="int(11)" null="0" default="0"/> <field name="allowed" type="text" null="1"/> <field name="lasttime" type="int(11)" null="0" default="0"/> <field name="readtopics" type="text" null="1"/> <field name="currvisit" type="int(11)" null="0" default="0"/> <key name="PRIMARY" unique="1" columns="userid"/> <key name="currvisit" columns="currvisit"/> </table> <table name="kunena_smileys"> <field primary_key="yes" name="id" type="int(4)" null="0" extra="auto_increment"/> <field name="code" type="varchar(12)" null="0" default=""/> <field name="location" type="varchar(50)" null="0" default=""/> <field name="greylocation" type="varchar(60)" null="0" default=""/> <field name="emoticonbar" type="tinyint(4)" null="0" default="0"/> <key name="PRIMARY" unique="1" columns="id"/> </table> <table name="kunena_subscriptions"> <field primary_key="yes" name="thread" type="int(11)" null="0" default="0"/> <field primary_key="yes" name="userid" type="int(11)" null="0" default="0"/> <field name="future1" type="int(11)" null="1" default="0"/> <key name="thread" unique="1" columns="thread,userid"/> <key name="userid" columns="userid"/> </table> <table name="kunena_subscriptions_categories"> <field primary_key="yes" name="catid" type="int(11)" null="0" default="0"/> <field primary_key="yes" name="userid" type="int(11)" null="0" default="0"/> <field name="future1" type="int(11)" null="1" default="0"/> <key name="thread" unique="1" columns="catid,userid"/> <key name="userid" columns="userid"/> </table> <table name="kunena_thankyou"> <field primary_key="yes" name="postid" type="int(11)" null="0"/> <field primary_key="yes" name="userid" type="int(11)" null="0"/> <field name="targetuserid" type="int(11)" null="0"/> <field name="time" type="timestamp" null="0"/> <key name="postid" unique="1" columns="postid,userid"/> <key name="userid" columns="userid"/> <key name="targetuserid" columns="targetuserid"/> </table> <table name="kunena_users"> <field primary_key="yes" name="userid" type="int(11)" null="0" default="0"/> <field name="view" type="varchar(8)" null="0" default="flat"/> <field name="signature" type="text" null="1"/> <field name="moderator" type="int(11)" null="1" default="0"/> <field name="banned" type="datetime" null="1"/> <field name="ordering" type="int(11)" null="1" default="0"/> <field name="posts" type="int(11)" null="1" default="0"/> <field name="avatar" type="varchar(255)" null="1"/> <field name="karma" type="int(11)" null="1" default="0"/> <field name="karma_time" type="int(11)" null="1" default="0"/> <field name="group_id" type="int(4)" null="1" default="1"/> <field name="uhits" type="int(11)" null="1" default="0"/> <field name="personalText" type="tinytext" null="1"/> <field name="gender" type="tinyint(4)" null="0" default="0"/> <field name="birthdate" type="date" null="0" default="0001-01-01"/> <field name="location" type="varchar(50)" null="1"/> <field name="ICQ" type="varchar(50)" null="1"/> <field name="AIM" type="varchar(50)" null="1"/> <field name="YIM" type="varchar(50)" null="1"/> <field name="MSN" type="varchar(50)" null="1"/> <field name="SKYPE" type="varchar(50)" null="1"/> <field name="TWITTER" type="varchar(50)" null="1"/> <field name="FACEBOOK" type="varchar(50)" null="1"/> <field name="GTALK" type="varchar(50)" null="1"/> <field name="MYSPACE" type="varchar(50)" null="1"/> <field name="LINKEDIN" type="varchar(50)" null="1"/> <field name="DELICIOUS" type="varchar(50)" null="1"/> <field name="FRIENDFEED" type="varchar(50)" null="1"/> <field name="DIGG" type="varchar(50)" null="1"/> <field name="BLOGSPOT" type="varchar(50)" null="1"/> <field name="FLICKR" type="varchar(50)" null="1"/> <field name="BEBO" type="varchar(50)" null="1"/> <field name="websitename" type="varchar(50)" null="1"/> <field name="websiteurl" type="varchar(50)" null="1"/> <field name="rank" type="tinyint(4)" null="0" default="0"/> <field name="hideEmail" type="tinyint(1)" null="0" default="1"/> <field name="showOnline" type="tinyint(1)" null="0" default="1"/> <key name="PRIMARY" unique="1" columns="userid"/> <key name="group_id" columns="group_id"/> <key name="posts" columns="posts"/> <key name="uhits" columns="uhits"/> <key name="banned" columns="banned"/> <key name="moderator" columns="moderator"/> </table> <table name="kunena_users_banned"> <field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/> <field name="userid" type="int(11)" null="1"/> <field name="ip" type="varchar(128)" null="1"/> <field name="blocked" type="tinyint(4)" null="0" default="0"/> <field name="expiration" type="datetime" null="1"/> <field name="created_by" type="int(11)" null="0"/> <field name="created_time" type="datetime" null="0"/> <field name="reason_private" type="text" null="1"/> <field name="reason_public" type="text" null="1"/> <field name="modified_by" type="int(11)" null="1"/> <field name="modified_time" type="datetime" null="1"/> <field name="comments" type="text" null="1"/> <field name="params" type="text" null="1"/> <key name="PRIMARY" unique="1" columns="id"/> <key name="userid" columns="userid"/> <key name="ip" columns="ip"/> <key name="expiration" columns="expiration"/> </table> <table name="kunena_version"> <field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/> <field name="version" type="varchar(20)" null="0"/> <field name="versiondate" type="date" null="0"/> <field name="installdate" type="date" null="0"/> <field name="build" type="varchar(20)" null="0"/> <field name="versionname" type="varchar(40)" null="1"/> <field name="state" type="text" null="0"/> <key name="PRIMARY" unique="1" columns="id"/> </table> <table name="kunena_whoisonline"> <field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/> <field name="userid" type="int(11)" null="0" default="0"/> <field name="time" type="varchar(14)" null="0" default="0"/> <field name="item" type="int(6)" null="1" default="0"/> <field name="what" type="varchar(255)" null="1" default="0"/> <field name="func" type="varchar(50)" null="1"/> <field name="do" type="varchar(50)" null="1"/> <field name="task" type="varchar(50)" null="1"/> <field name="link" type="text" null="1"/> <field name="userip" type="varchar(20)" null="0" default=""/> <field name="user" type="tinyint(2)" null="0" default="0"/> <key name="PRIMARY" unique="1" columns="id"/> <key name="userid_userip" columns="userid,userip"/> <key name="func" columns="func"/> <key name="time" columns="time"/> </table> <table name="kunenadiscuss"> <field primary_key="yes" name="content_id" type="int(11)" null="0" default="0"/> <field name="thread_id" type="int(11)" null="0" default="0"/> <key name="PRIMARY" unique="1" columns="content_id"/> </table> </schema>
Any ideas?
Thanks again
GW
14 years 8 months ago #105642 by Matias
Database looks OK, so I'm beginning to think that the issue is in your Kunena template. Can you try default and report if it works?
14 years 8 months ago - 14 years 8 months ago #105730 by gwmbox
I have already tried the default template, if you go to my site you will see it is set to the default template, still no luck.
GW
Last edit: 14 years 8 months ago by gwmbox.
14 years 8 months ago #105764 by Matias
I think we need to look closer into this issue.
Am I right:
* users can go to editor and type message
* SUBMIT -> empty page above
* Topic wasn't created
Open editor HTML and find out the URL where form is sent to. What was it?
What is the URL to that "empty" page?
Do you have any SEF components installed?
14 years 8 months ago - 14 years 8 months ago #105818 by gwmbox
Yes you are right in your list
The URL of the page when a post is submitted is dogsites.com.au/forum/post/
No SEF add-ons are installed, just using the built in Joomla SEF.
Here is the source of the page to add a post
<span class="kfooter-time">Time to create page:&nbsp;1.34&nbsp;seconds</span>
Thanks for your continued help
GW
Last edit: 14 years 8 months ago by Matias.
14 years 8 months ago #105821 by gwmbox
hmm.. I made a reply but it now will not show, might be because the source was long????
Are you able to see the post?
GW
